post your remote filter mounting pics
Moderator: Tom Notch
adjunog
Post by adjunog » Tue May 15, 2018 7:34 pm
I'm planning to put a remote filter that does require to cut some of the engine mount plate. Are you mounting off the exhaust, behind fender, or your own mounting? I would like to get some ideas and suggestions from y'all. Thanks.
Jadewombat
Re: post your remote filter mounting pics
Post by Jadewombat » Sat May 26, 2018 9:32 pm
Mine is mounted off the bottom of the engine case, a little off to the side but minimal length on the hoses (about 12" each).
