The amount of wires I need to run for stereo equipment exceeds the capacity of the hole that the wiring harness comes through. I could remove the protective grommet to make more room, but I would rather not do that. I suppose I could also drill a second hole and install a generic gromet and run the cables through there.
How have you done this in your bug? If drilling is necessary, should I go through he other side of the vehicle to keep speaker wires away from the harness?
I've needed to do that a couple of times (different cars) and I've just cut a 2nd hole and used a generic grommet. No problems too it. Just double check both sides before drilling.
Steve
Sounds like a good idea..
Keeping the RCA's,Speaker wire ...
away from other power sorce is a good Idea
Just find a good spot so the wires dont get rubbed down & shortout..
Peace
