any ideas on wiring one of these in?...wiring diagram? any advice/help would be awesome. i'm pretty new at this so visuals would be a bonus.
thanks
J
second/backup battery
I'm no electrician but since nobody else did i figure might as well post a reply.
I could see having the two batteries connected to a switch box to select current. They have battery kill switch's, you could do it very simply by having two kill switch's so one battery could be on and the other could be off. Have those two run to a connecter block like they use in car audio applications.
I dunno about this but you might be able to daisy chain the two negative terminals and a two to one switch box to select battery source.
- unclejohns78
