A Penthouse Diary
Moderators: Leatherneck, rickosuave1987
birddog1148
Location: In my Brewery playing with cars, Sandusky OHIO
Contact:
A Penthouse Diary
Post by birddog1148 » Wed Mar 01, 2017 9:19 pm
[IMG]//uploads.tapatalk-cdn.com/201703 ... 170d9e.jpg[/IMG]
So I thought I would get your attention.
Figured it was time to get working on this.
[IMG]//uploads.tapatalk-cdn.com/201703 ... 30b8d8.jpg[/IMG]
I have had this urge to get something for camping since the drop camp we did for Elk last fall. Thought about a teardrop camper, then a pop up, and when I had about mentally committed the money to that I had an epiphany, build the bus to an off road camper like I originally wanted.
From what I remember I could not drive it because every time I would come to a stop it would die.
[IMG]//uploads.tapatalk-cdn.com/201703 ... 9958e4.jpg[/IMG]
I have a new carb supposed to hit my doorstep on the 6th. I think I want to get it going so I can enjoy it and build it kind of slow like I did the Baja. Figured you guys would both encourage and cajole as I go along. The shop has gained some new toys since I was last active to include a milling machine, a plasma cutter, a 20 ton press, a sand blaster and I am working on a forge to cast with.
I have some ideas and decisions to make on how to do it and what to use, but let's start this again.
Sent from my SM-T567V using Tapatalk
I may look dumb, but that's just a disguise, I'm a master-mind in the field of espionage!
birddog1148
Contact:
Re: A Penthouse Diary
Post by birddog1148 » Thu Mar 02, 2017 5:16 am
So I found these tires, they are not the Treadwite's I normally use but the price looks good
https://www.tirerecappers.com/tires/mud ... ga-mud-mt/
Contact:
Post by bajaherbie » Thu Mar 02, 2017 7:12 pm
Didn't Treadwright change the name after a buyout or something?
Sent from my SM-G920R4 using Tapatalk
birddog1148
Contact:
Post by birddog1148 » Thu Mar 02, 2017 9:03 pm
Treadwite's still is Treadwite they send me emails from time to time. This other company's is different and Treadwrite doesnt offer any 14 in tires.
Got my carb today, hopefully can work on it this weekend, have a rifle match Sunday.
birddog1148
Contact:
Post by birddog1148 » Fri Mar 03, 2017 3:09 pm
Been doing a lot of thinking and rediscovered Blind Children Racing and looked at the lift spindles how to. And the wheels started turning. If you can combine two VW spindles to make a lift spindle, why not make a hybrid? I have this '96 Ranger with a 2.3 that I am thinking about using in VW, either the bus or the Baja. And I could turn the bed into a trailer but had no plans for the front. Why couldn't I use the ranger spindles, and brakes and do the BCR lift spindles? I admit the little looking at the spindles was on the internet but the idea intrigues me.
Sent from my E6782 using Tapatalk
cbeck
Post by cbeck » Fri Mar 03, 2017 6:06 pm
Now you got my wheels turning. TTB instead of a beam or spindly looking a arms....
birddog1148
Contact:
Post by birddog1148 » Fri Mar 03, 2017 8:41 pm
Got it started, gotta dig it out of the front room of the Brewery
birddog1148
Contact:
Post by birddog1148 » Sun Mar 05, 2017 2:49 pm
[IMG]//uploads.tapatalk-cdn.com/201703 ... d6d752.jpg[/IMG]
First time outside since 2012 I think
Contact:
Post by Leatherneck » Mon Mar 20, 2017 9:32 pm
Glad you found a good use for it, going to be a good one for your off road camping.
birddog1148
Contact:
Post by birddog1148 » Mon Apr 03, 2017 10:52 am
Ok been having trouble getting signed in. Its up on jack stands in the back room of the shop. Got 3 of the 5 tires mounted, the retreads from Tire Recappers in Nashville. passenger side frame rail is almost repaired, working on the cross members and outriggers next. Will work on getting some pictures.
Contact:
Post by Leatherneck » Tue Apr 04, 2017 7:24 pm
I went on their site trying to find some 33X15 recaps, no dice. Outriggers?
Reason: dbl post
birddog1148
Contact:
Post by birddog1148 » Tue Apr 04, 2017 7:57 pm
Outriggers are parts of the crossmember outside the frame rail, Jack points are part of them as well.
birddog1148
Contact:
Reason: dbl post
birddog1148
Contact:
Post by birddog1148 » Thu Apr 27, 2017 8:38 pm
Contact:
Post by Leatherneck » Sun Apr 30, 2017 10:40 am
Tire has some meat to it.
