***Leathernecks rail ***
- Leatherneck
- scott the viking
- scott the viking
Yes...the pressure has to be low even with paddles (if you want them to work like they should). Paddle tires were just not something I could afford as a teenager...so I tried about every type of tire I could get my hands on for next to nothing. I used to get out of date tundra (not the Toyota) tires off of small aircraft. They were wide and had that smooth ribbed tread. I would take a hot knife and cut what looked like knobbies out of the ribs. like this
The cutting DID make a difference on my old water pumpers. But they were so heavy and really lacked the kind of traction a VW with half the power had. By the time I got into VW powered rails...I could afford paddles. However...my Brother could not, so he would cut tires for his VW rail...we really could not tell much difference between a cut tire or an uncut on his rail. What would make a HUGE difference is tire pressure...even a pound less would make it go places that it would not go before. We just kept letting air out, a pound at a time until one came off the bead, then we went up one pound. This is especially true on low powered cars, the difference a few pound of air can make in the tires is something you will have to experience to believe. You will go from holding your car at half throttle and running high heat just to keep it moving at a decent pace, to kind of floating along effortlessly.
- Leatherneck
- shmoishere
- bajaherbie
- scott the viking
Sure...I had a set on a manx. They have a nice soft side wall and bumble along pretty good. I had kind of a terra tire on my bug for a while and they didn't do too bad either. If you have a low powered car and don't really go to the dunes that often...the desert traks like you have are your best bet.
- Leatherneck
I hate it when he calls our ORV's low powered. I'm going to install a couple of those motors you put on a bicycle to help you up hills, then we will see who is low powered.
Bajaherbie, I talked to Norm, Abram that is and he said if you are using it for non woodworking and it is between 12:30 and 4:27 it is ok to use the blades.
- Leatherneck
