Ricko's New Ride-'71 Baja
Re: Ricko's New Ride-'71 Baja
Mr. Suave, lookin' mighty nice! Funny how a good build is so much improved by the right fenders sitting at the right height. Cruz in fun dood; sit low in the seat, elbow out the window and lookin' gud.
rickosuave1987
Post by rickosuave1987 »
Well I finally got the car (mostly) back together after welding in a new bung for the inner pivot.
Only took me 2 1/2 months... :roll:
Baja
HookIt
SuaveRacing FaceBook
Devastator
Post by Devastator »
rickosuave1987 wrote:Well I finally got the car (mostly) back together after welding in a new bung for the inner pivot.
The helicoil didn't hold? :shock:
Devastator's Build Thread
Sandrail
going fast enough."
Mario Andretti
rickosuave1987
Actually it was my safety wire that didn't hold :oops: The safety wire broke or came undone (not sure which), and the bolt back out enough to ruin the threads again...
Turned out not to be too hard to just cut it out with a torch and welding in a frankenstein piece off of a new pivot.
Baja
HookIt
Devastator
rickosuave1987 wrote:Actually it was my safety wire that didn't hold :oops: The safety wire broke or came undone (not sure which), and the bolt back out enough to ruin the threads again...
That sucks! It also sucks that the Helicoil argument will never be settled now. :?
Sandrail
going fast enough."
Mario Andretti
rickosuave1987
Devastator wrote: That sucks! It also sucks that the Helicoil argument will never be settled now. :?
Yea, sorry I couldn't settle that argument properly. :cry:
The threads were still somewhat intact after the last incident. But the hole had become oblong, so there was no way I could snug the bolt down well.
Baja
HookIt
winifredevw
Post by winifredevw »
rickosuave1987 wrote: Actually it was my safety wire that didn't hold :oops: The safety wire broke or came undone (not sure which), and the bolt back out enough to ruin the threads again...
Are you going to safety wire again, or try something else?
rickosuave1987
winifredevw wrote: Are you going to safety wire again, or try something else?
Not entirely sure just yet. The hole in the new pivot bolt will probably accommodate a 1/4" bolt and I could bolt it through the gusset right above. I also picked up some safety wire that says it is good for up to 25 lbs. I am not sure if that is a good number or not though...
Baja
HookIt
bolt it.......
winifredevw
I might be a little biased, but I like Skid's fix. :)
Devastator
bajaherbie wrote:bolt it.......
X2.
Sandrail
going fast enough."
Mario Andretti
takotruckin
Post by takotruckin »
Damn Rick, you work as fast as I do :lol:
CopperBaja
Post by CopperBaja »
Rick, in your defense, I don't get in the garage much when it's hot either....August/September are the worst.
Devastator
CopperBaja wrote:I don't get in the garage much when it's hot either....August/September are the worst.
That's for sure!
Sandrail
going fast enough."
Mario Andretti
CopperBaja
Devastator wrote:That's for sure!
Dude...you're in AZ...where I live gets hot...but doesn't compare, I'm sure. 8)
