NQ JQKE
NQ JQKE
Post by david58 » Sun Mar 30, 2008 8:30 am
I condensed my build thread these are pics taken between Nov 08, 2006 thru Mar 27, 2008. Man time flies.
This is my son Curtis on his first welding job. We watched the bug me video on heater channel replacement when he was here at Thanksgiving. I decided to weld the reinforcements to hold the body and keep it from flexing instead of screwing it in place. I am taking pictures and watching and him work.
Here is Curtis’s best weld so far.
Here is a couple shots of the spot weld removed.
ChadRat wrote:rusty heater channels, man I hate those. One of the reasons I went to a rail. Fixin rust is not fun.
Yeah but to quote my son Curtis “Oh I can do that!” He is really trying to get the right side out I told him it was going to be harder to fix because of the rust. I didn't realize how many little spot welds there really are. He almost has the right side out.
I wanted to do the bodywork with Curtis so he could see first hand what it takes to really do body panel replacement. Which, I have no clue of how to do. Tomorrow we’ll clean up the new heater channel fit the right door and do some dirt dobbin.
I bought heater channels from cip1 the ones for no heat look at the differences in the their shape.
I decided to modify the front firewall to fit the rest of the 3-inch lift kit by leaving 3-inches of the original firewall in the car. I thought it would be easier to cut thru the sheet metal with a hole saw to install the roll cage, than thru the Up Your Bug part that came in the kit.
Anyone ever do a brush guard on their Baja?
Last welding done now ready to sandblast.
I got the floor pan and tunnel back today from Miller protective coating. I got to say they did a fantastic job sandblasting and primering it. Tonight Doug is dropping by from Line-X to pick it up and put a coating on it.
Line-X looking good.
I got the running gear bolted in. Still have to switch the spring plates out. I bolted the beam in.
I forgot I loaned my engine hoist out so the body will sit outside. See that oil that's from that ford. The red one. :lol: His leaks worse than mine.
Brake parts and a few other odds and ends.
I'm just getin started. :D
WOAH looky here. :lol:
Nice welding Hedrock. Thank you Soooo Much. :wink:
This is the bare beam ready for primer.
Here is the primed beam.
Here is is painted Chebie urnge. :lol:
nukeworker
Post by nukeworker » Sun Mar 30, 2008 9:28 am
REALLY cool 8) Love to see build pics. Always learn something new. Thanks.
Dodahsand
Post by Dodahsand » Sun Mar 30, 2008 10:52 am
You need to stop and take a good close look at what you are doing... Your about to run out of Bud!
Post by Leatherneck » Sun Mar 30, 2008 11:03 am
Man, I am going to report you to the UPLFO for making your son work on the bug in just his underwear. :shock:
Baja is coming together, lot of progress. What did you figure out on the arms?
Hedrock
Post by Hedrock » Sun Mar 30, 2008 11:04 am
Dodahsand wrote:You need to stop and take a good close look at what you are doing... Your about to run out of Bud!
I think he brews it in the backyard :wink:
Looks real good David... The brush guard is way cool looking 8)
Post by bajaherbie » Sun Mar 30, 2008 12:14 pm
i drink keystone light beer, i'm lookin for quantity and not quality.... :lol:
Post by david58 » Sun Mar 30, 2008 1:00 pm
Leatherneck wrote: Man, I am going to report you to the UPLFO for making your son work on the bug in just his underwear. :shock:
That is one Hard Headed Youngun. :shock:
Leatherneck wrote:Baja is coming together, lot of progress. What did you figure out on the arms?
Well for now I am going to make fake shocks just to hold it up at the ride height I want. That way I can get another set of coil overs, and still be able to move the car around.
Post by Ol'fogasaurus » Sun Mar 30, 2008 1:16 pm
Looking good. Your rosette weld sure look better than mine did and you were using the thinner pan halves.
I am curious, in the front, by the frame head, you took out the two formed humps on the underside of the pan. Why?
Post by david58 » Sun Mar 30, 2008 1:25 pm
Ol'fogasaurus wrote:Looking good. Your rosette weld sure look better than mine did and you were using the thinner pan halves.
I had a guy guy do the welding.
The only reason they were taken out was because the PO had installed a reciever and welded it on so I used the torch to remove it.
Post by Ol'fogasaurus » Sun Mar 30, 2008 2:20 pm
Thank you. I also like the brush guard. Did you make it or is it for something else that you modified to fit? It really does look like it belongs there.
Post by david58 » Sun Mar 30, 2008 2:44 pm
Ol'fogasaurus wrote:Thank you. I also like the brush guard. Did you make it or is it for something else that you modified to fit? It really does look like it belongs there.
I think it came off a 2000 Toyota.
Post by david58 » Tue Apr 08, 2008 5:40 pm
Post by Leatherneck » Tue Apr 08, 2008 7:05 pm
What is left on the to do list?
namelesswonder
Post by namelesswonder » Wed Apr 09, 2008 12:01 pm
That bright red/orange is pretty amazing.
Franz the Thunder Pumpkin!
Permanent member of the "Baja may not be running" club
Post by david58 » Wed Apr 09, 2008 12:43 pm
Leatherneck wrote:What is left on the to do list?
Lots.
