936 a reBUILD thread
BAJA-IT
Post by BAJA-IT »
Sense the car was built back in 1996, I thought I would call this a rebuild thread and show what I am doing to the car as things are repaired, modified or just updated.
This winter we are updating the steering with new bearings, u-joints, shaft and steering wheel coupler. We are also going through the engine. Replacing the pistons and cylinders, after getting sanded earlier in the year. We will also be replacing the bearings and what ever we find worn when we split the case. The heads have already been looked at and had to have some guides replaced, but are now ready to go back on the engine. New oil hoses will be going on the car the winter also.
The car has had lots of repairs over the years as thing have broken. I may get some of those pix up too.
Here is the shaft after it came out of the car
I had to cut the shaft to get it out because I didn't have the same u-joint when one went bad and had to weld it in.
Had a box show up the other day and these were in it.
And another box showed up with these in it.
Here is the old mount for the shaft, modified once before.
Here I am cutting off the old mounts.
Mounts all cleaned off.
BRAT Motorsports #936
Re: 936 a reBUILD thread
what brand are those u-joints? nice looking for sure. i bought mine(Sweet Mfg.) from Speedway Motors, nice but not as nice as yours :shock: :lol:
kyle_pc_75
Post by kyle_pc_75 »
Glad you started this thread. It'll show what goes into a winning race car. Now if you could just convince some of us Utah slackers to build you some competition.... :roll: :lol:
Kyle
Qurtys Lyn
Post by Qurtys Lyn »
kyle_pc_75 wrote:Glad you started this thread. It'll show what goes into a winning race car. Now if you could just convince some of us Utah slackers to build you some competition.... :roll: :lol:
Kyle
It would be nice to not have to beat up on the mini trucks. :lol:
I may have some pictures of interest for this thread. Let me check.
Fusername's evil twin
'72 Std Beetle - 1641 CC
BAJA-IT
Post by BAJA-IT »
bajaherbie wrote:what brand are those u-joints? nice looking for sure. i bought mine(Sweet Mfg.) from Speedway Motors, nice but not as nice as yours :shock: :lol:
I got them from Woodward Steering on the internet.
http://www.woodwardsteering.com/index.p ... Itemid=581
http://www.woodwardsteering.com/images/ ... joints.pdf
The ones I got are splined on both ends and can be replaced easily if needed.
BAJA-IT
Post by BAJA-IT »
I made a couple of fire extinguisher mounts for the car over the Summer.
This is the second one.
The first one I made mounted in the car ready to go.
BAJA-IT
Post by BAJA-IT »
Here's a couple pix of the car minus the skin.
front
back
Qurtys Lyn
With the skin on:
Steekers, In the shop:
In Motion:
Qurtys Lyn
Front arm stops:
BAJA-IT
Post by BAJA-IT »
Thought i would post up some carnage pixs from days past. Some of the fun parts of racing.
These are from breaking an axle.
Inside of the axle tube retainer with axle.
Bell from the axle tube.
Spade end of axle.
And the side cover.
BAJA-IT
Post by BAJA-IT »
This is what happens when you get tagged by a 5-1600. This happened at the Balls Out race at Barstow I believe in 2006. I was about a 1/4 mile from the finish right in front of our pits. Didn't even get a sorry from the guy that hit me.
Here's where it turned into a low rider...........well one side did anyway.
And a better pic of the cause.
BAJA-IT
Post by BAJA-IT »
This last set is what happens when you roll the car at around 40-45 mph. Car rolled 4 times and landed on the wheels. Only scrapes and bruises to the occupants. Well it did hurt my pride a little......ok a lot. :(
Bent the left front trailing arms.
Without the tire and wheel.
Bent the top of the engine cage, right side.
Smashed the KC light.
Bent the spare tire hold down/jack handle/lug wrench.
Cracked the left rear down tube weld from previous repair.
Cracked the exhaust.
Even popped the center out of the passengers PTT button.
Also destroyed the right rear wheel, no pix though. We had to pry it off with the lug wrench to put the spare on.
Qurtys Lyn
Don't forget you bent the shock towers up front as well.
1966bajabug
Post by 1966bajabug »
Qurtys Lyn wrote:Don't forget you bent the shock towers up front as well.
Has anyone ever told you that you talk to much?
Thanks for posting the pics and info about them. Looks like this one has brought lots of fun among other things. :D
