936 a reBUILD thread
BAJA-IT
Re: 936 a reBUILD thread
Post by BAJA-IT »
I believe it was this one that I used.
https://www.superbrightleds.com/moreinf ... 1744/4257/
BRAT Motorsports #936
BAJA-IT
Post by BAJA-IT »
Sense it was raining all day Saturday and I couldn't work on the Baja, I went down to my dad's house and worked on the race car.
The axle tubes are now installed on both sides, all the way to the brake drums.
Now I need to add gear oil and install the starter and I can reinstall the engine. Shouldn't take long to have it ready to race again.
JUSSUMGUY
Post by JUSSUMGUY »
You have had 2 ring and pinion gear failures in recent years that I know of. Both at BAP. I always remember your car finishing so not having many/any failures in the past. Why do you think they are failing? The quality of the material the gears are being made of? Or???
Qurtys Lyn
Post by Qurtys Lyn »
The Flasher my Dad linked is the one we used, Kyle.
Fusername's evil twin
'72 Std Beetle - 1641 CC
dustymojave
Post by dustymojave »
JUSSUMGUY wrote:You have had 2 ring and pinion gear failures in recent years that I know of. Both at BAP. I always remember your car finishing so not having many/any failures in the past. Why do you think they are failing? The quality of the material the gears are being made of? Or???
Dyke jump maybe?
:shock:
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
1966bajabug
Post by 1966bajabug »
Heavy right foot through the rough stuff at BAP.
BAJA-IT
Post by BAJA-IT »
Trying to stay with those fast guys! :shock: :oops: :lol: :wink: :cry:
Qurtys Lyn
Dyke jump maybe?
:shock:
Dyke jump is nice and smooth. There's a few other holes out there that are pretty bad though.
The hole we think did it is between mile 5 and 6 on the course. We hit it pretty hard.
dustymojave
Yeah the dyke jump is smooth, but its an opportunity to get a substantial difference between wheel speed and ground speed. That is one of the worst issues for a gear box. But there are many opportunities for harsh treatment for gear teeth around there.
Richard
Retired Fabricator
BAJA-IT
Post by BAJA-IT »
Trans is filled with gear lube, starter is back in and the axel nuts are torqued.
Time to put the engine back in and the rear cage on.
BAJA-IT
Post by BAJA-IT »
Did a leak down on the engine yesterday
#1: 99/100 1%
#2: 99/100 1%
#3: 93/100 7%
#4: 97/100 3%
The leakage on #3 is into the case, so I think the rings may have lined up. No hiss in the exhaust or intake.
Should have the back end buttoned up soon.
TimS
Post by TimS »
how many races on that engine? That's pretty good.
BAJA-IT
Post by BAJA-IT »
Not sure Tim, I would have to check with my engine builder (my Dad) but I think it has 6 or 7 races on it now.
BAJA-IT
Post by BAJA-IT »
The engine is back in and all hooked up, air, elec., oil and throttle. The rear cage is back on with all it's war wounds. Need a new bungee for the right limit strap and put on the rear wheels and tires, check the brake adjustment with the wheels on and the back end will be ready to go.
Just need to replace one TRE and vacuum the seats and we will be ready for Vernal.
Leave in 12 days, race in 14. :D :D
