Topic of the Day...
Re: Topic of the Day...
I understand about the heights... for sure.
The machinist bit sounds good as it is good to know for at home atleast if not for full time. I always wanted to do that myself but my eyes would have kept me out of it.
I looked up Jimco but tgere are a lot of companies using that name. I'd still do some asking ariund as there are so many schools out there that I am a bit leary of.
- bikesndbugs
http://www.jimcorace.com http://www.jimcorace.com
I like that but the money isnt there as far as a fabricator/welder. I do know someone that owns another comany http://www.mikesmetalworks.net/Home.html
As far as schools around here my current welding class is at a high school as an adult night school. There is "summit college" down the street and thats all i know of and a couple community colleges around.
Travis
I did see that Jimco and you could learn a lot there; I'd just worry about the work cycles.
The other construction co. might have their ups and downs (pun partly intended). Would your TIG work for you there?
I think you said your GPA was 4.0 and that should help you get into college. A two year degree from a reputable college is always a game changer... in most jobs. I'm not sure about some of the schools I am hearing about now which is why I recommend you doing your home work on them.
- bikesndbugs
cumulative is 3.6 or so now and 2 years accept anyone here. as far as the construction company im not sure i need to talk to him.Ol'fogasaurus wrote:I did see that Jimco and you could learn a lot there; I'd just worry about the work cycles.
I was accepted to a couple of 4 years but i dont wanna do that and really dont want any debt.
Travis
- bikesndbugs
So welding class is going good im getting alright at it but i want to mess with some tubing. Ive got like 3 ft of tubing and 2 ft of 2"x1/8" flat stock. Any ideas of what i can make that would be helpful to a bug
Sent from my HTC Desire 626s using Tapatalk
Travis
Interim bumper ????
- bikesndbugs
maybe or something similar.Ol'fogasaurus wrote:Interim bumper ????
that gave me the idea of making a shelf in the nosecone. tubing is a it big for that i think.
DUsty had mentioned a body support to prevent sagging doors. i might be able to make that out of it.
Travis
The body supports would have to be longer tban that. When I built the body lift and the stiffener going down the body mount channels I started out with 6' of tube per side. The doors are probably longer than 2' each. The support is a great idea and I would add it high up on my list if I were you. I was having a off site conversation on rock sliders with someone just before I headed south; a replacable combination stiffener and a smooth rock slider that also protects the body mount bolts also. Wouldn't work that well on the sand but might be really good on not the best of/no trails.
- bikesndbugs
As far as the door braces i think dusty was saying it goes in tgr trunk area for on a one piece because you loose alot of body strenth cutting it away. The lite bar might be a good idea
Travis
- dustymojave
You got it right.As far as the door braces i think dusty was saying it goes in tgr trunk area for on a one piece because you loose alot of body strenth cutting it away.
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
- dustymojave
About the schooling...
I advise you to beware of trade school sales people who tell you all about how many with a certain skillset are needed in the work place. I have learned to trust them like Americans traditionally trust used car sales people.
Richard
Retired Fabricator
Retired Fabricator
What Dusty said!
Honesty is long gone pretty much everywhere which is why I suggested you talk to honest employers (hard to find also) for their opinions. There isn't much sacred now days but figure: if it sounds too quick and easy easy... it probably is. I was watching one of those ads on TV where your experiences are worth a quick pass in some areas getting you their degree quicker.
- bikesndbugs
Two pieces of plate or sheet metal in an L welded to the tubing then bolted through body in that spot where heater hoses come up and a across the spot i cut?dustymojave wrote:You got it right.As far as the door braces i think dusty was saying it goes in the trunk area for on a one piece because you loose alot of body strength cutting it away.
sound right.
Travis
If you are running a tube orcsomething like that through a structural like a firewall and have a flat plate that attached to that panel and a double on the other side make sure that neither of the plates are the same size. If they are then you increase the chance of the body panel fatuging (metal fatuge) then cracking/failing. The same if the tube does not go through the panel but uses the plates as the join.
