Houdini the Baja Bus
smiley
Re: Houdini the Baja Bus
Post by smiley »
Yeah. Bigger whiteboard! I keep finding more stuff to do!!
Thanks for your input on the brass tubing. I don't forsee a problem, the mate who's system I have copied has been in has daily driver bus for the last 8 years with no issues. But it is something I will keep in mind for a redesign in the future.
I pretty much used the fittings that I could get and what would fit on the car. It is a bit harder to get the stuff you want where I am located. I am hoping to get a lathe at some point so I can just make the fittings etc that I need.
And you are right about the hose. I had a bit of a brain lapse when I put the clamps on and realised just after i did it. I am going to see it I have enough extra length to just nip the ends off and refit them. One more thing for the whiteboard!!
Smiley :)
smiley
Post by smiley »
Made a start on the rear bar this afternoon.
I want to to look basically the same as a stock one. But it will be 100x100mm box with the stock bar wrapped around it. It will also have a hole in the middle for the tow hitch. And eventually I will add the swingout tyre carrier for the spare too.
You can see in the next picture that I don't want to drop the bar at all from its currently position. It will foul the exhaust tip. I might even raise it slightly so I can redo the exhaust at some point to get a little more clearance under it.
It's official, buses look completely weird with the rear bar removed. Gives a bit better view of the new heat shield though :)
Here is the box sitting in place. It is currently too long. I am going to trim it back to the same width as the chassis rails in the back, 1115mm for those playing at home. Was actually a lot easier than I thought to cut through it with the 100mm grinder.
Bar sitting back in the stock location...
...but now it has the box insert sitting inside it :D
That's all I got done today. Hoping to get the mounting plates fabbed up tomorrow so I can mount the box up to the chassis.
Thanks for looking.
Smiley :)
smiley
Post by smiley »
Got a little more done this arvo on the rear bar.
I noticed when I removed the factory bar, that the brackets bolt to the underside of the chassis with two M10 bolts. But there is a third threaded hole in the chassis a little further forward. I ran a tap through all of them and will be using all three for the mounting plates. Does anyone know what the factory used the third hole for?
I am using some 40x40mm angle that will bolt up to the underside of the chassis and weld to the bar.
In addition to the angle I am making some side plates out of 6mm plate that will weld to the ends of the box and cap them off. I am basically copying Andrew's bar he made for his bus but changing a few things. His build here http://www.manxclub.org/phpbb3/viewtopi ... 2&start=60
The plates will bolt through the chassis with some M12 bolts and crush tubes. Just have to make sure that it clears the rear engine mount bar.
While I was lying under the car looking at how I was going to mount the bar I noticed that the flange for where the exhaust tip bolts to the muffler was cracked on the underside. I removed the muffler and gave the crack a cleanup, and then laid a bit of weld in there to fix it up. I was lucky enough to have some new exhaust gaskets left over from my dad's bug (we ended up with two sets for some reason). So I refitted it back up with the new gaskets.
Then I spent a while taking a lot of measurements and working out where I want the box and rear bar to sit. I have decided to lift it up 15mm higher than factory. And the gap between the rear or the body and the box will be 30mm. Then I drew this all out on a cardboard template to see if it would fit. I like to write the measurements straight on the template for a quick reference. Then I tried it on the car, I had to adjust a few dimensions to get it to fit perfectly. Also sat the box in place on jackstands to offer the template up to it.
Last thing I got done this afternoon was to let the hole through the centre of the main box for the tow hitch box to go into. First I marked out the centre point on the main box and marked out where the hole needs to be for the smaller box to go through.
You can see in the previous picture that the corners of the small box are very rounded. I didn't want to be filling up large gaps with weld. I wanted to make the join as snug as possible so the welds can be airtight and strong. In the future I would like to used the large box section of the barwork as an air compressor tank.
With that in mind I measured the radius of the corners and used a 20mm drill bit to put the curves in that I needed. Then I just cut the straight edges with a thin cutting disc and tapped the waste out with a hammer. Ended up with a nice pair of home made Iron Crosses at the same time :)
With the holes cut I just had to tidy the perimeter up a little with the die grinder until the small box was a nice fit. I can tap it through with a hammer and block of timber. The final length still needs to be worked out. It will need to protrude through the stock bar enough that I can get the hitch pin in it. I will be sticking it about 5mm through the front side so I can get a nice weld on it.
As always, thanks for looking.
Smiley :)
smiley
Post by smiley »
This is the rear bar bolted up in the factory location. I was messing around trying to work out where to fit the trailer plug on the rear bar. I am aware that there is currently one in the engine hatch but there is no wiring to it and I don't want it there, I also think that the tyre carrier might get in the way of plugging the cable in.
I though maybe I could fit in in between the box and the rear of the body. But with it in place that gap to the back of the vehicle looks horrible. The bar is stood off a mile. It doesn't look so bad in the pictures, but in the flesh it looks like the bumper is falling of the back of the bus. Way too much gap.
Even with the box pushed in to where I plan to run it has more gap than I thought it would. The next picture the box is gapped to the back of the bus and the bumper is pushed as far over it as possible. But hoping that the tyre carrier will mask some of this gap.
I cut out the mounting plates that will be welded to the ends of the box section. I have also cut some 40mm angle that will be bolted to the underside of the chassis too. Will get some more pictures of this tomorrow.
When I cut the plates out I drilled some 10 or 12mm holes at the inside of the radius of any corners. I didn't want to cut squarely into the corners with the thin cutting disc and create a stress area that cracks could start at. Has to be strong enough to snatch 4WDs out when they get stuck, so don't want it snapping of the back of the bus!
I dropped the 100mm box off to get sandblasted inside and out. I am planning to use the box as an air tank so I wanted it clean inside. Prior to welding it up I will spray some oil in it for the time being to stop it rusting up. Then later I can add fittings and pressure relief etc.
Next up I started work on the cold air intake for the engine. I bought some tube and bends off eBay. And was trying to work out the best way to mount them to the side of the engine bay.
I was around helping someone with a few things on their bus and noticed that it had factory mounts for an intake pipe. Because my bus is injected it had the airbox mount but not these two intake brackets. So I went and had a look in the back of one of the Bay wrecks that I have and sure enough, it has the mounts. Cut them out with a cordless grinder and they happen to be the perfect size for the 2.5 inch tubing. And the hose clamps I have fit nicely into the back of them.
Started mocking up where I wan the intake to run. I wanted it a bit higher in the bay than this to get it up clean of the battery and out of the way.
I ended up cutting one side of the 45° bend as short as possible. This brings the bend closer to the intake where it clamps on and further away from the side wall of the engine bay. So it angles up for longer and tucks up higher out of the way.
I cut one leg off the alloy tubing to shorten it up to hug around the corner of the firewall above the battery. The piece I cut off happened to be the perfect length to put between the 45° and 90° blue bends. This is the intake pipe all assembled how it goes in the car.
I fitted the intake mounts using nutserts. I figured bolting them it was easier than trying to weld in the engine bay. And they are super easy to take in and out now too. The first one is basically where the factory had it. And the one above the battery I moved further out to the right of the car to support the end of the tube as much as possible.
I clamped the intake in place before getting a picture of the second mount. It is under that hose clamp there.
Intake all fitted in place.
Looking down the hatch in the back.
Heaps of clearance above the battery.
And that's how you fit a cold air intake to you bus :)
Thanks for looking, more soon.
Smiley :)
CentralWAbaja
Post by CentralWAbaja »
Nice work as always Smiley!
smiley
Post by smiley »
Thanks mate. I can't wait to see some new pictures of yours!!
Got some more work done on the rear bar before the Warwick VW Drag weekend.
I cut the hole in the rear bumper for the tow hitch to come through. I drilled the corners first with a 10mm drill to get the corners of the hole a nice radius.
I decided to fit the trailer plug through the box section. But because I want to use the bar as an air tank this means keeping it all airtight. So I picked up a length of heavy wall tubing, sliced a bit off and will weld it in place to create a void for the plug to go in so I don't have to space the rear bar a km off the back of the car.
The tubing I got is seamed. So when I cut the slot in it I made sure that I cut the seam out of the tube. One less weak point to worry about.
I worked out where I wanted it on the box and marked and cut it out so the tube was a nice hammer fit.
A little tidy up and you can see where the plug will sit. I have some 6mm plate that will also get welded on top of the bar. This is so I have something to bolt the plug down to without drilling holes in the box section. Still needs to be trimmed to shape and welded on.
Back to the bar mounts. It was suggested from a friend that I drill the mount bolts through the chassis and clamp through the whole thing. He said the thread in the chassis isn't the strongest. He has done the same thing on his bus and tows a car trailer with it so no arguments from me.
You can only do it with the front two bolts. The rear one is inside the pillar at the back of the engine bay so you can't get to the top of it.
Then I bolted up the mounting plates. They are only tacked together at the moment. The large side plate will be bolted through the chassis in three places. Only one for the time being. There was one 10mm holes in the chassis already that I am using. But the engine needs to come out to drill the other two, these will be 12mm. I will also enlarge the other one to 12mm too. And the 40mm angle is bolted up through the chassis in the 3 factory holes. I made some plates out of 6mm that sit on the top in the engine bay.
You can see in the next picture how the box will be welded to the mounts. The side plate caps the end of the box and the angled piece will be welded to the side of the box. I tacked it, then removed the angled piece so I could fully weld around the end of the box and make an airtight seal with the end plate. Then the angle was welded on second.
I took the box section and had it blasted. So it would be a bit cleaner inside and nicer to weld up.
Smiley :)
smiley
Post by smiley »
I fitted the tow hitch box section into the main bar. Then level this up behind the bus. I used the blue screw jackstand to tune in the angle of the tow hitch. I measured the roof gutters of the bus with an angle finder and made it the same angle on the tow hitch. So should be level if the bus is.
Then I tacked it up so I could see how it looked before I welded it out. I Trimmed the hitch back too, left it a little oversized so I can set the right length later.
I welded the hitch in first. Then both ends. Then fitted it back to the bus so I could tack the angled pieces in place and then weld them on too. I think it pulled a little when the angle was fitted. It was a little tighter on the chassis and needed some hammering to get on. This doesn't really bother me. Once it is finished and on for the final time I don't intend on removing it again.
I welded a couple of nuts on the ends so I could bolt the bumper in place to head down to Warwick (900km each way). Will make some better mounts now that I am back. The towball is just in there for show. I hadn't drilled the pin hole at this point.
I am happy with how it looks. It has spaced the bumper out a bit. But I think the tyre carrier will cover this up. It is super strong and that is what is most important.
Drove the car down 900 odd km to Warwick for the VW drags. I am fortunate that my grandma lives 30km away the next town over. So I always have somewhere nice to stay every year when I go down for the drags. I gave the bus a good wash the Friday before the show.
Bus setup next to the drag strip watching the racing. Was going to put it in the show and shine, but we liked having the shade a lot more. Plus he doesn't exactly shine :D
This afternoon I finished off the trailer hitch on the bar. I marked then drilled the holes through for the pin.
Then I trimmed off the excess length I didn't need.
I slid the towball as far in as it would go and used the hitch as a guide to add a new set of holes in it. So now I have two different spots it can be at. But I think I will just use it on the holes that have it furthermost in.
So now we have towbar! Just need a plug and it should be good to go. That's all for now folks.
Thanks for looking.
Smiley :)
ajdenette
Post by ajdenette »
Smiley have you thought about putting a sleeve in the frame where your through bolts go through to prevent crushing the frame?
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
smiley
Post by smiley »
ajdenette wrote:Smiley have you thought about putting a sleeve in the frame where your through bolts go through to prevent crushing the frame?
The chassis is pretty stout and I haven't noticed any crushing at all yet. But I will likely get my hands on some tube that will take a 10mm bolt and add some in there next time the bar is off. I just need to drill the holes out slightly bigger.
Thanks for the concern.
Smiley :)
smiley
Post by smiley »
I put my trailer on the bus the other day to see how it looked. I was expecting it to be a lot more nose up. But I think Houdini's saggy butt has it sitting fairly level.
Took a mate that was visiting for a day for a run out to 5 Rocks. Haven't been out there since the bus has been lifted so was interested on how he would go. Was a bit softer than last time but made it up the big dune to get in no worries. This is us at the top. Had to air down a bit though :)
Drove up through the small township and out onto the headland. Got some good pictures. Scott had a far more fancy pants camera than me. So when I get some pictures off him I will post them up too.
Headed down to the beach and cruised around some more. Found some rocks to flex on. Houdini is a little lacking. But when I get back in the car the front right compresses up a lot more.
I was very happy with the way the bus performed in the sand. With the tyres down and the mass balanced a little more to the rear with the new back bar he got the power down nicely. You have to back off with the grunt of the Type 4 otherwise he just wants to spin wheels. Have to just let him chug of through.
Was a great test run before Fraser this weekend to check things and get a feel for the bus.
Smiley :)
smiley
Post by smiley »
After the beach run I got started on fitting up another oil cooler. With the Summer heat already getting up around here and the Fraser trip looming I thought it would a good addition to keeps the temps down. Longer term plan will probably be to swap one or both of these small coolers out for a large one with a thermostatically controlled fan.
The new cooler is mounted to the same frame as the first one.
I also added an extra support bracket to hold the centre of the frame up and stop it sagging in the middle.
All plumbed up. You can also see the extra brace. It bolts through an 8mm holes that was already in the tophat frame.
Last time I had the engine and box out I noticed some play in the front mount. This demonstrated itself on the sand with the engine revving itself up and down slightly at points. So I ordered a new mount when I got some other parts.
Here is the old mount removed.
Unfortunately the new mount was a different shape. Slightly smaller and more rounded on the corners that face towards the front of the car. I thought that perhaps my mount cradle was beginning to wear out. So I grabbed another cradle be came up with the same result, the new mount is just the wrong size.
You can see the gaps in the corners of this picture.
The old mount was actually still in good condition. Just a little loose in the cradle. So I decided to deck the back of the cradle where it sits against the gearbox. This will clamp the rubber up tighter and take the slack out of the mount.
I trimmed about 2-3mm off the cradle with the grinder and then flattened it out with a hand file. You can see the inside is polished up from the rubber moving back and forward in it.
This did the trick and the mount bolted up far more firmly in the bus.
Today I also added a plug under the back seat for the fridge. Still have to run some wire to it. Will be 6mm straight from the battery.
That's all for now. Will get some pictures on the Fraser run.
Thanks for looking.
Smiley :)
All very nicely done!
smiley
Post by smiley »
Piledriver wrote:All very nicely done!
Thanks mate. I redid the hose ends while I was under there. Still had enough length in the hoses to cut the ends off and redo them with no hose clamps on the An fittings.
Smiley :)
Smiley, you aren't towing a car like I do with my motorhome but the comment about strengthening up the hole in the hitch where you locking pin comes through might be an idea worth considering. Just a localized doubler around the hole should help with any oversized pull on the trailer and wearing/tearing the hole where the pin comes through. I have seen trailer hitches with the pin hole elongated before. It wouldn't surprise me that using a couple of thick washers wth tight fitting holes to match the pin hole, one on each side of the hole would suffice for the doubler.
I had a trailer hitch break on me this year while towing my dink (dingy/car). Luckily I wasn't on the freeway yet, but a few hundered feet from it. People driving by commented that they had never seen a hitch break like that. The break was in the radiius of the ball mount. We are required when towing over a certain weight to have a break-a-way system that locks the brakes up on the trailer or dink. When that happened both of the safety straps broke in two pieces and the dink was left sitting in the middle of the road. Better that I guess than have it go flying across the median and into on comming traffic.
You did a nice looking job in your hitch build and hiding the hitch. Good to see you are radiusing the corers also.
smiley
Post by smiley »
A few pictures from a Rover Scout camp I went down and helped out at last weekend. Was held and Awoonga Dam near Gladstone and we went out to Boyne Island/Tannum Sands Saturday.
I took a canoe down, towed my trailer down with a tent in it and took 3 people down and all their camping gear. And Friday's temperature was like a firestorm from hell. Probably the worst conditions I could have towed in with all that weight. Oil temp was at about 100°C most of them time but did come down a bit on the flat and coasting down hills. Very happy with how it went, but would still like to add a fan to one of my coolers.
This is Friday Afternoon when we showed up.
Saturday morning down at the beach. I nabbed a good spot right next to the sand and put the awning out for everyone. The shade was most welcome.
I backed into the park. People were guiding me over next to the gutter but no one was looking behind me. I stopped the bus and got out to set up and thought, "That ute is a bit close". Probably could have just put a feeler gauge between them! Lucky I didn't go back any further. In my defense though, I am in my park :)
A nice picture from the canoe.
Was a little windy but the awning stayed put all day. Lucky I had some big sand pegs to hold it down.
Saturday afternoon we went down to the dam for a swim. We were camped at the Scout grounds about 500m away so I took about 10 people down in the back of the bus. I drove all the way to the water's edge.
A few other people came down as well in 4WDs. None of them could drive back up the bank to camp because the ground was a little loose and rocky. They all had to put it into 4WD. I offered them a tow :) Gee they make easy poop look hard sometimes. Houdini chugged back up there without even a hint of wheelspin, even with the extra bodies on board (the extra mass might have helped!)
If anyone wants to know what the tent looks like. This is why you need a trailer to move it :)
All loaded back up and ready to cruise home Sunday.
Thanks for looking everyone
Smiley :)
