Here We Go: DD Build
Re: Here We Go: Desert Dynamics Build ( Desert Dynamics Sucks )
Do you still have the front arms they came on the car and are you wanting to get rid of them
I've been watching you on this build for a month or so now, it seems like you're attending to a lot of the same details I did with my Desert Dynamics car
Yes, It's been a process for sure. I still have my orig arms, but holding onto them.
Showing the positioning of the spindle end sleeve.
- Leatherneck
Your welds are looking a whole lot better, your getting there.
Thanks, but a long way to go. Granted this weld washer on the lower bulkhead was out of position, and pretty cramped, but, well, yea..
From this point forward I would like to be called "Master Fitter." Good thing I'm not good at baiting hooks.
1.75" lower tube, inner sleeved with 1.5" and outer sleeved at the ends with 2".
- Leatherneck
Nice job there Master tube guy.
Thanks Leather. I went back and made some adjustments to the prior sleeves. A bit OCD but much happier. Finished up the driver's rear chassis sleeve tonight. Front BPs finally arrived tonight as well.
- petew
Noice. Rather complicated way to make a solid metal bar though.
Thanks Pete. Looking forward to getting this front end sorted some day.
Maybe the name "Tube-y" is more appropriate! A lot of fitting has gone on there to be followed by a lot of melting and filling. Very impressed! Any plug welding to be done?
Thanks. No plug welding. Bungs have 3-4 rosette welds each (main tube and main tube extensions/inner sleeves). There's so much length for welds for the outer sleeves that I can't see a reason for rosettes for those.
Nothing to report today. After working out last night, I was just too spent to mess with the a-arms. I did, however, order my rear sneakers (BFG KM2 33x12.50). For what it's worth, 4 Wheel Parts has a pretty darn good deal on them right now ($390 for the pair) and free shipping. So, there you go.
- Leatherneck
Is that shipped?
