Here We Go: Desert Dynamics Build ( Desert Dynamics Sucks )
petew
Re: Here We Go: Desert Dynamics Build ( Desert Dynamics Sucks )
Post by petew » Wed May 02, 2018 7:39 pm
Ah well, done now. Good work. Now make it run! :)
DeMinimis
Post by DeMinimis » Wed May 02, 2018 7:50 pm
Thanks Pete.
DeMinimis
Post by DeMinimis » Thu May 03, 2018 4:52 pm
Standing on her own for the first time ever. It will be short-lived. Wheel studs aren't long enough for these meaty Method wheels. Need ones 12-15mm longer. Clearance at full lock worked out!
Post by bajaherbie » Thu May 03, 2018 7:11 pm
Keep it up!
petew
Post by petew » Fri May 04, 2018 1:48 am
Yay!!! :D
Keep going! If you're fast enough I can pop buy in 3 months for a ride. :wink:
CentralWAbaja
Post by CentralWAbaja » Sun May 06, 2018 8:04 am
Nice job man keep it up.
Skidmark
Post by Skidmark » Sun May 20, 2018 11:29 am
Looking good, dude! Tacos... you need more tacos to help make it run.
"Your car sounds angry, and it wants to go fast all the time..."
(quote from my daughter, after driving my car)
It's not complicated, it's just expensive...
DeMinimis
Post by DeMinimis » Sun May 20, 2018 11:57 am
Cerveza might help with all this cypherin'. Still messing with caster, camber and toe at midstroke and level. Caster 8+ for both. Good there. Camber at 2.5 and 2.4 (I may lower those with a half turn. Trying to determine if better to be slightly over or slightly under the 2 degree mark). Sitting on the ground now while I adjust toe in. Toe close to 1/8, but not perfect yet.
petew
Post by petew » Mon May 21, 2018 4:44 pm
That's really cool! Keep going. You can do it! 😊
dustymojave
Post by dustymojave » Tue May 22, 2018 6:34 pm
Are you adjusting it at parked height or loaded ride height?
Richard
Lake LA, Mojave Desert, SoCal
AKA: MojaveRacer208
DeMinimis
Post by DeMinimis » Tue May 22, 2018 6:44 pm
Mid stroke. Well, just shy of that actually. I understand 60/40 is about where you want ride height, so that's what I'm using when trying to dial it in. I understand I may be tweaking it more once built.
Post by Ol'fogasaurus » Tue May 22, 2018 8:28 pm
While I am sure you already allowed for it: just-in-case, don't forget to add the proper weight for fuel and passengers (et al) when setting things up. I've seen it done wrong a couple of times and it wasn't that easy to get the adjustments right after getting off on the wrong foot.
Post by bajaherbie » Tue May 22, 2018 9:40 pm
Have you considered a Subaru engine for your buggy?
DeMinimis
Post by DeMinimis » Tue May 22, 2018 9:51 pm
Silly BH.
dustymojave
Post by dustymojave » Thu May 24, 2018 6:57 pm
Then "Herbie" wouldnt be appropriate or relevant, would he? 8)
Lee,
See above:
Question already asked.
Richard
AKA: MojaveRacer208
