68 baja build
- TimS
Re: 68 baja build
Yes. You can swap them around. I think one is 17mm and one is 19mm. I ended up using 22mm off of a super beetle in my rear when I went to type 3's and 19mm up front but I have e the larger bus master to compensate. I'm sure there is a chart or a post somewhere about what sizes were made through the years.
- bikesndbugs
Re: 68 baja build
anybody know what kind of lugs i need for the centerlines? 5lug
got the rear seat pulled put today and most of the interior removed
Travis
- chuckput
Re: 68 baja build
For Centerlines you will need ball seat and not a tapered cone seat lug nuts. Tapered cone lug nuts have a 60° taper on them where the lug nut makes contact with the wheel, and the ball seat lug nut is rounded as the name implies.bikesndbugs wrote:anybody know what kind of lugs i need for the centerlines? 5lug
- bikesndbugs
Re: 68 baja build
thank you also found some spacers that go from taper to ball seat one is actually stuck to my wheel right now.chuckput wrote:For Centerlines you will need ball seat and not a tapered cone seat lug nuts. Tapered cone lug nuts have a 60° taper on them where the lug nut makes contact with the wheel, and the ball seat lug nut is rounded as the name implies.bikesndbugs wrote:anybody know what kind of lugs i need for the centerlines? 5lug
Travis
- bikesndbugs
Re: 68 baja build
so i pulled out some cut down drums today to see how they fit on the wheels. WHY IS THERE SUCH A gap arounf the lug? seems dangerous
plans for the light layout
the back is pretty rusted out (rust neutralizer and bondo?) bought rust nuetralizer and bondo
also grabbed my spindles from the yard the rusty one has a inner bearing practically stuck to it
ive been looking for a complete beam drum to drum.just so i dont have to deal with all the hassle of cleaning mine up and rebuilding it. also got a cigarette lighter and usb ports
some ideas for what to paint it
Travis
- dustymojave
Re: 68 baja build
Looks like a score on the wheels and tires. The wheels do not look to be actual Centerlines, or even bolt-together 2-piece like CMS. But they appear to be cast imitation Centerlines, and those are fine. Not quite as light. Plenty sturdy. My friend had a set on his Baja and used stock lug nuts. Those look like they've been used with stock lug nuts too.
I approve of the flat black on the steering wheel center. Chrome wheels are good for blinding the driver at the worst times.
Richard
Lake LA, Mojave Desert, SoCal
Retired Fabricator
Retired Fabricator
- dustymojave
Re: 68 baja build
Number 3,5,6, 7, 8, and 9 all look very 70's-80s. That's not a bad thing, I suppose those your age who knew that would call it "retro". My preferences are a close dice between #1 and 4, followed a little ways back by #9. None of your sketches are ugly.
For the rust fix, one of the 1st things to fix would be the window seals that let the water inside in the 1st place.
The lug stud holes in the wheels are large so the wheel centers on the ball shape of the lug nut. Some other cars like my son's 4th Gen Jetta, use "hub-centric wheels, that center on the hub itself.
Richard
Retired Fabricator
Retired Fabricator
- bikesndbugs
Re: 68 baja build
ya i was going for a bit of an 80s look for those I like it. My uncle did the rear window seals before i bought it so thats done i hit it with some rust neutralizer now im gonna bondo up the holes. Got a shift rod bushing and aluminum quick shift kit yesterday. Ordered the rear lights last night. IM really pushing to find a linkpin panhead for not a completely insane price.
Travis
- bikesndbugs
Re: 68 baja build
having major issues with finding a linkpin panhead that doesn't cost an arm and a leg even used i cant find any. on the positive my shifter doesn't feel like trash anymore with a new shift bushing and the quick shift kit.
Travis
- bajaherbie
Re: 68 baja build
#5 and #8
- bikesndbugs
- bikesndbugs
Re: 68 baja build
Might be trading for a one piece bug eye fiberglass are there any cons for a bug eye
Travis
- bikesndbugs
Re: 68 baja build
https://www.instagram.com/p/BLcGpKqDoz6/
replaced the ground strap and got it running. Its got an occasional backfire out the exhaust does it at idle and at revs any idea what it might be?
Travis
- bikesndbugs
Re: 68 baja build
any ideas on the backfire i messed with the timing a bit that didn't help.
Travis
- dustymojave
Re: 68 baja build
Could be a vacuum leak.
The 1-piece Bug eye is fine if it's going to be pure offroad. For dual purpose, it gets more air under it, along with more water, mud, etc. So it requires more effort sealing up the electricals and dash.
Richard
Retired Fabricator
Retired Fabricator
