Roll call...
- bajaherbie
Roll call...
Just curious how active this forum is. It used to be a hopping place but activity is way down thanks to Facebook and others such as Instagram.
I don't participate much in the FB baja/off road groups but have seen several STF members being active. I don't follow any dirt stuff on IG but follow stuff like fishbras, barstoolsports, electricalhacks, kidsgettinghurt, etc...
Anyway, post something on this thread if you still read here occasionally.
Re: Roll call...
I don't do those other things. Too easy to get snagged by those who don't have scruples.
- ajdenette
Re: Roll call...
I am in the Bus barn but read what goes on here and post when I can.
Alex
|_________oo_oo
/ /__/____[_____\
I I======[]IIIIIII[]
()_)-----()_)----)_)
|_________oo_oo
/ /__/____[_____\
Re: Roll call...
Absolutely 0 interest in facebook, not one of the cool kids. I scoll thru here every couple days. Took a .5 hour ride the other day while setting a new record 80* high temp. This morning 1.5"snow.
- BajaBug222
Re: Roll call...
Still here... still adding to the Baja
- chuckput
Re: Roll call...
I check what's going on almost every day.
- CentralWAbaja
Re: Roll call...
I still stop by almost daily.
Mostly pissed that all the pics are gone.
Re: Roll call...
An empty bladder is a good thing! Good to hear you are OK.
- bikesndbugs
- bikesndbugs
- bikesndbugs
- Skidmark
Re: Roll call...
I still pop in occasionally
"Your car sounds angry, and it wants to go fast all the time..."
(quote from my daughter, after driving my car)
It's not complicated, it's just expensive...
Re: Roll call...
I always stop in and try to see whats going on. In the middle of going from 2.5 front arms which I tore up and torsion leaves to 4" longer arms. The 4" arms will have 10" dual rate coil overs and a much beefier beam than my old off shore beam. I have a confession I have also been to the Engine rebuild forum and lately I have frequented the forced induction forum oh and ahh did I mention I have also been with Engine managment I am here now and am having thoughts of coil overs .....Front and rear
Terry
Terry
Terry Lytle
Canada
2180
8.5-1 comp
JE forged pistons
Porsche piston squirters
30mm triple "O"ring pump
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
SL-1 Turbo prepped heads
Canada
2180
8.5-1 comp
JE forged pistons
Web 86 a
1.4 ratio rocker
MS3 PRO ecu
Mini Cam Sync
LS2 coil
50mm Throttle body
TD04L-13T Turbo
Re: Roll call...
I try to check in once or twice a week to see what's going on.
BRAT Motorsports #936
