Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Moderator: seabeebuggy
mactaylor
Re: Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Post by mactaylor » Sun Aug 05, 2018 6:56 pm
Hi bug66. What are the specs on your turbo if you don't mind me asking?
petew
Contact:
Post by petew » Mon Aug 06, 2018 12:05 am
You should definitely put a turbo on the black car! :twisted:
bug66
Post by bug66 » Mon Aug 06, 2018 3:37 am
Too small :shock: :mrgreen:
It’s a T3/T4, stage 3, whatever that means.
I think the next will be a custom Precision 5862
2165cc T3/T4 turbo, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Kalle
Post by Kalle » Mon Aug 06, 2018 8:52 am
They are already far above 400 whp at a lot lower boost than last year! And still fat and safe. Keep on with the good work M8!
-K-
Post by Chip Birks » Mon Aug 06, 2018 12:13 pm
Sweet! Goes to show that you don't have to have a crazy high tech turbo to get good numbers. Though it certainly does make it easier I suppose!
bug66
Post by bug66 » Mon Aug 06, 2018 1:09 pm
Old turbo design, small 2165cc engine.
But 501,5whp and 667nm/492 ft lbs to the tires!
Pig fat and lazy ignition, but it got there without a hiccup!
mactaylor
Post by mactaylor » Mon Aug 06, 2018 3:18 pm
Pete I am onto it! Just gathering parts. Thanks bug66.
mactaylor
Post by mactaylor » Mon Aug 06, 2018 3:26 pm
Awesome numbers by the way!
Post by Chip Birks » Mon Aug 06, 2018 4:19 pm
Well done! That should get you a 9! Good luck!
Amurray
Post by Amurray » Thu Aug 09, 2018 12:09 pm
WOW! :shock: at what boost was that? This give me something to look forward to when I get back to the dyno with the new clutch in. I have no clue what my #s would be. I do not have the water to air intercooler but I do have an air to air on a 2234cc engine. I just hope it works out this time.
Congrats on your #s very impressive :wink:
bug66
Post by bug66 » Fri Aug 10, 2018 1:47 am
Boost at peak hp and torque was 2,1 bars and dropped to 1,9 at 7000. Either due to a leak or that the turbo can't deliver the pressure. Will go over and check for leaks etc. :)
Kalle
Post by Kalle » Mon Aug 20, 2018 5:31 am
Come on mister.... show us your timeslip(s) from SCC!
-K-
Wally
Post by Wally » Mon Aug 20, 2018 7:50 am
bug66 wrote:
Sun Aug 05, 2018 5:11 am
Nah, engine and trans will go into the new car I’m starting on this fall.
Narrowed and raised rear etc. Should get some meat under the rear fenders also :)
New car? Do tell more about that! Bug also or different platform?
PS congrats on the dyno numbers, awesome results! and I did not expect such huge gains tbh.
And congrats on your new PB, 10.2 if I got it right from FB right?
T4T: Type 4 Turbo engine, under construction
bug66
Post by bug66 » Wed Aug 22, 2018 5:13 am
10,221 felt good!
The 60-foot is the best I've done at 1,404. There are more to do on both launch and big end. But I see I need a speed sensor to build more boost in 3rd and 4th than in the two first gears. Kind of slippery from time to time.. :D
https://www.facebook.com/81361943872825 ... v6M53S_OjQ
bug66
Post by bug66 » Wed Aug 22, 2018 5:21 am
A '59. Narrowed and lowered (raised transmission)
More to come when I pick it up.
