My ongoing Turbobaja build
Re: My ongoing Turbobaja build
Very Nice and definitely impressive!!!!
Ohhh....and it didn't happen unless there is a vid!!!!
- Chip Birks
Doesn't that dyno sheet say max boost of 9.36 on the 240 run?
- sweetlokin66
sweet man
- woodsbuggy1
Very Nice, you should be proud!
- turbobaja
His reasoning was the same everyone uses, that basically the more overlap you have the more you're pushing the charge out the exhaust valve at the beginning of the intake cycle with boost pressure. My concern is that I'm loosing bottom end grunt with this much overlap, and only 8.1:1 CR. This cam is NOT that aggressive in the big picture. Similar to a W120, 86A, etc. I'd like to do a "quick swap" to dual IDF pattern T-bodies to see if it's my single t-body and plenum size/design effecting the low rpm behavior.Chip Birks wrote:Very impressive! Whats the problem with 108lc? My 108 cam encourages spool way faster than the old 110lc setups did.
Karl
DON'T QUIT
DON'T QUIT
- turbobaja
Yeah...I wish I took some pics or a video, but I didn't do either . Mario took some pics and a video that might not have very good sound. We had people stopping by from local businesses commenting on the sounds it was making !Clonebug wrote:Ohhh....and it didn't happen unless there is a vid!!!!
Karl
DON'T QUIT
DON'T QUIT
- turbobaja
We're not sure why, but his reading was consistently lower than the logged boost pressure and my mechanical gauge reading. He T'd a ??bar sensor into my 3" pre-throttle charge pipe. My MAP sensor and boost/vac gauge is obviously tapped into the plenum. I don't know if it's location or calibration that made the difference, but we're trusting what the car is telling us for now.Chip Birks wrote:Doesn't that dyno sheet say max boost of 9.36 on the 240 run?
Karl
DON'T QUIT
DON'T QUIT
- turbobaja
I had to resist the urge to take Mario off-roading on our test drive. We had fun boosting up a couple hills. I think we got a little sideways going over the railroad tracks once, that got his attention .andy198712 wrote:246... in a baja! mad!!
Well done!
Karl
DON'T QUIT
DON'T QUIT
Did the cruise tuning session help?
I find it difficult to tune by myself and paying for someone in the right side seat is usually money well spent.
I hope to do another one next summer but with some dyno time included.
- turbobaja
It definitely helped having a capable tuner in the passenger seat with me. On the dyno we varied the load through the cruise area and ended up with a rather rich cruise tune down in the lower rpms. It's just what the engine seemed to like better. Cruising above 3K is much easier to tune and freeway speeds its smooth as butter.Clonebug wrote:Did the cruise tuning session help?
The most frustrating problem I still have is it bucks and jerks bad at times. Almost always very very light throttle application and also on closed throttle decel. I'm going to double check and possibly re-route my throttle cable to see if engine movement is effecting throttle movement at all. If I force my foot against the tunnel to stabilize my light throttle application it seems to smooth out or avoid the bucking altogether, sometimes. I drove it in 2 parades last night and learned to very very ...very gently apply throttle as I rubbed the clutch and kept it pretty smooth. I need a progressive throttle body or something, lol.
Karl
DON'T QUIT
DON'T QUIT
I had the same problem and we tuned it out with ignition and fuel.
Cruise at 25 and 35 mph in town at around 1800 rpm 2nd or 3rd gear was annoying to say the least.
I think we cranked the advance up to get rid of it.
Have Mario work on the tune in the map area while you drive.
- MarioVelotta
We where able to add timing, out to 50°+ and afr from 11- 16:1. It was just really happy at about 45 with 13:1. No misfires and really smooth.
I love your intercom Karl, that was priceless!
[email protected]
[email protected]
MarioVelotta wrote:We where able to add timing, out to 50°+ and afr from 11- 16:1. It was just really happy at about 45 with 13:1. No misfires and really smooth.
Was it that loud????
- MarioVelotta
Small bay + open exhaust = Yeah, loud enough haha.Clonebug wrote:MarioVelotta wrote:I love your intercom Karl, that was priceless!
I was able to pull this frame from the video, kinda cool
[email protected]
[email protected]
