Update,
Since I have my King Pins redone it was time to fix my frontend.
I measured up the offset on the upper and lower arms and came up with 7.0mm on both sides. That makes it easy enough to shim at 5 shims per side on the top and bottom since the arms are from a 59 frontend.
I got the spindles installed, torqued and the caliper mount also installed.
I took the rotors into the local machine shop that did my rear rotors and had the studs installed.
Since there are thicker areas and a few webs it made it a little more involved for the machinist and he and I agreed that the holes needed to be spot faced to give clearance.
Once that was done I installed the races, greased up the bearings and installed the rotors onto the spindle.
What I found out was that these are ball joint rotors and they have a set of bearings that are king pin inner and ball joint outer bearing sizes. They say to use the existing thrust washers but they are way to large to fit so now I have to find myself a set of Ball Joint washers.
Also, the left side clamp nut they sent is a POS and doesn't seem to go on very straight so I am going to get a new one of them also.
On a good note when I installed the right side caliper it bolted right on without shimming anything. The existing brake hose works and it fits nicely.
I pulled the exhaust off the engine to re-weld my EGT bung since if it leaks it will be a PITA to get the EGT out again to weld when the buggy is put back together. My weld looks like crap......
My plan is to go to Monroe tomorrow if it works out and get my ECU modified for the EGT input and also have Mario tig up my EGT bung to make sure it won't leak.
Since I am so close to the engine being apart I just might have to pull the stock heads and re-install the DRD's.......
