Safari Turbo/Megasquirt Fuel Injection Project
Moderator: seabeebuggy
buguy
Re: Safari Turbo/Megasquirt Fuel Injection Project
Post by buguy » Mon Jan 29, 2018 10:50 pm
Is that a US dollar?!
petew
Post by petew » Mon Jan 29, 2018 11:03 pm
Yes, so by the time it gets to whoever does it, it will have cost me AU$2.00. :roll:
Clonebug
Post by Clonebug » Sat Mar 31, 2018 11:48 pm
Mileage, 89,777
It's been almost 3 months since I really drove the buggy except for a couple 5 mile trips to town and back.
I had a couple issues and today I finally had time to look into them.
First issue was the whistling sound I had when the buggy was on the dyno. I had convinced myself it was a bearing going bad in my el-cheapo Chinese alternator.
I started it up today and was was bothered by a starting issue on top of the noise. So once the noise came I shut off the engine, pulled the fan belt and fired it back up. The noise was still there....hmmmm.
I started pushing around on the intake and on the right side silicone connector I could get it to be quiet when I put pressure on it.... I grabbed a 10mm socket and tightened both clamps on that side and....Voila!!! No more noise!!!!
I also went and snugged up the left side for good measure while I was at it.
Next was the starting issue. It seem like low voltage but every time I checked the battery it was a 12.6 volts...... So I pulled the battery and took it to Les Swab to test it and it came back good voltage but low amperage.
I spent a cool $132.00 for a new one and my starting issues are now gone.
Next was that bothersome low boost issue......if you can call it low..... :roll: :wink: :lol:
I had a sneaking suspicion that the intake leak had some effect on my total boost output so I went and fueled up and took it out for a test run.
Second gear felt really good and third was pulling like a sum-beach and then the clutch started slipping....... :cry: :cry:
Glancing at the gauge at full throttle I saw it past the 20 lb. mark and could tell by the pull that it was back.
With the clutch now complaining I tried it a couple more times and it definitely had more power.
Looking at my logs I showed 22.1 lbs boost in third gear at 4600 rpm and my IAT's were dropping down as the boost rose!!!! I showed 67.8 degrees F IAT's at 22.1 lbs boost!!!!
That is unbelievable!!!!
No wonder the clutch won't hold. With the vacuum/boost leak fixed the engine runs completely different and idles a lot nicer. I'll have to let autotune run a bit to clean things up again.
I just can't believe my IAT's though..... that is amazing!!!
The fan is connected and working but I haven't noticed it except once the other day I shut it off in the garage for a bit and when I went to start it to go again the heat soak kicked the fan on due to the parameters Mario and I set.
It must be helping a little.
I'm off to the Portland Swap Meet next Weekend so hopefully I find some things I never knew I needed. :wink: :lol: 8)
Post by Chip Birks » Sun Apr 01, 2018 12:36 am
You sound like me, got a list of winter upgrades to get done, and just now starting. Mine went into the garage today to begin the tear down.
rubenski
Post by rubenski » Sun Apr 01, 2018 3:00 am
Makes me consider putting a air to air intercooler on my build too.
Just to be safe.
andy198712
Post by andy198712 » Sun Apr 01, 2018 5:56 am
How old is the clutch? think its wear adding to the excess power? or just need a stronger clutch either better disk or pressure?
Hope your well!
Clonebug
Post by Clonebug » Sun Apr 01, 2018 10:29 am
Hope your well!
It started slipping at around 23 lbs. boost without the intercooler after a couple speed shifts this early fall.
Now it won't hold at even 20.5 lbs boost hitting fourth gear and 22 lbs. going to third.
I can see the rpm rise on the log right where the clutch starts slipping. The moment it hits full boost it just won't hold anymore.
Considering the Stage I clutch is advertised to hold 180 ft lbs torque and I am getting 201 ft lbs. at 20.5 lbs. boost I would say I had a pretty good run with this Pressure Plate.
I have a Stage II PP waiting for me to pick it up next weekend......I 'm just not sure if I want to go through the work of installing it at this time.
The weather totally sucked for working on the buggy the last 3 months with cold, snow and rain so I put it off.
I even thought about limiting the boost to 20 lbs to stay under the clutch limit but after testing last night I know that's not going to happen. :roll: :lol: 8)
It is a completely different animal once it hits 22 lbs and I still have a possible 2.0 lbs more in there if the intercooler doesn't rob too much pressure.
I'll go look at old junk carbs for 3 days......everyone is trying to sell an old Holley Carb for big bucks........ :lol:
Once I get back from Portland I'll have a new drive to get it done so I can kick my brothers *ss in his STI.
Post by Ol'fogasaurus » Sun Apr 01, 2018 12:02 pm
Art, once you have polished the disc and PP (bar-b-que'd the assembly) the tight connection will not get better... only worse. Do the switch now so you can enjoy the rest of the warm dry weather (when and if it comes). :roll: :lol: Hate to hear you have to be tow'd a couple hundred miles from home.
andy198712
Post by andy198712 » Sun Apr 01, 2018 3:47 pm
so its just plain old boost killing the clutch lol
Clonebug
Post by Clonebug » Sun Apr 01, 2018 4:26 pm
It's a disease..... :cry:
rubenski
Post by rubenski » Sun Apr 01, 2018 4:36 pm
But there is a cure!
Clonebug
Post by Clonebug » Sun Apr 01, 2018 8:43 pm
Yes there is...... :wink:
At approximately 5 whp per lb. of boost I am now at about 194 whp at 22.1 lbs boost. 1.5 lbs more and my disease will be cured when I hit 200 whp............ :lol: :lol: :lol: :lol: :D
Post by Chip Birks » Sun Apr 01, 2018 9:13 pm
More Clutch!!!
Post by Chip Birks » Sun Apr 01, 2018 9:15 pm
Just to be safe.
I'd definietly recommend an intercooler of any sort if doing a new build. Just start with that as part of your plan, build around it.
CobraJet
Post by CobraJet » Sun Apr 01, 2018 11:03 pm
What intercooler are you using?
