Safari Turbo/Megasquirt Fuel Injection Project
Moderator: seabeebuggy
MarioVelotta
Re: Safari Turbo/Megasquirt Fuel Injection Project
Post by MarioVelotta » Sun Jul 08, 2018 9:26 pm
Here I come with my holy grail ☺
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
Clonebug
Post by Clonebug » Sun Jul 08, 2018 9:30 pm
Bring it on!!! :wink: :lol: 8)
I can't wait to see what a high revving 1600 will do for power.
CobraJet
Post by CobraJet » Mon Jul 09, 2018 12:07 am
Awesome, your buggy really gets up and goes! What RPM were you shifting at?
Clonebug
Post by Clonebug » Wed Jul 11, 2018 11:22 pm
I shift between 5200-5500 rpm usually......rev limiter is set at 5700 rpm....for missed shifts and times I forget to shift.......
Most times I'm not even looking at the tach.......I'm just rowing through the gears.....trying to keep it straight.
rubenski
Post by rubenski » Wed Jul 11, 2018 11:48 pm
Clonebug wrote:I shift between 5200-5500 rpm usually......rev limiter is set at 5700 rpm....for missed shifts and times I forget to shift.......
That thing goes as straight as an arrow!
buguy
Post by buguy » Fri Jul 13, 2018 6:49 pm
Clone how much over ambient temperature are you seeing with the intercooler? Does it stay consistent with ambient temps? Like is it normally 10 degrees over etc...?
kangaboy
Post by kangaboy » Fri Jul 13, 2018 8:31 pm
Clonebug wrote:
Sun Jul 08, 2018 10:45 am
The intercooler is doing a fantastic job holding the IAT's down on boost along with the WI. I'm seeing 78* F. at 23.8 lbs boost in the month of June with cooler ambient temps. That is on a short boost run though.......
When the ambient temps get to 85* F. then the IAT's are around 107* F. at full boost.
Long boosted runs will raise the IAT's as everything gets heat soaked.
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
andy198712
Post by andy198712 » Sat Jul 14, 2018 3:38 am
That speedo is a joke isn’t it lol it’s just gets thrown around lol
Clonebug
Post by Clonebug » Sat Jul 14, 2018 9:15 am
Mileage, 91458
Well Crap........After almost 14 years and probably 60,000 plus miles my used clutch cable broke on us coming back from the Bay last night.......good thing I'm a truck driver and can shift without the clutch...... :lol: 8)
And to think I had the Wife talked into going to the PIR Races with it to watch Mario strut his stuff...... :roll: :cry: :cry:
Looks like we just might have to go in the Wife's CC now instead......oh well.
Anyone local to me have a spare clutch cable I can buy to save waiting for shipping????
turboedbug
Post by turboedbug » Sat Jul 14, 2018 9:26 am
where ya located?
I have one laying around.
Sent from my SM-J727T using Tapatalk
1969 beetle rolling subie power
Ej20k vf-22 roller bearing turbo
Wright gearbox pro street -soon to be suby 5 speed
EMS stinger 4424 ecu
Wide 5 discs all the way around
Post by Ol'fogasaurus » Sat Jul 14, 2018 10:34 am
I've been cleaning the garage lately... nothing there. I just checked my messy shed and I didn't find one in that mess either. What I thought I had turned out to be for something else.
Autovice/Bowwow was sold a while back and has moved to Monroe under new ownership. Its now located across from the fairgrounds on (I think) HWY 2.
Maybe this winter you can pull everything apart again :roll: and convert to hydraulic (not meant as being a mean or nasty idea).
Clonebug
Post by Clonebug » Sat Jul 14, 2018 11:01 am
where ya located?
I'm in Lynden up by the border so I don't think we can get farther apart......
rubenski
Post by rubenski » Sat Jul 14, 2018 11:04 am
How you you shift without a clutch?
Post by Ol'fogasaurus » Sat Jul 14, 2018 11:43 am
Carefully!
You have to match RPM with gear box speeds. Unless you have an old Chev (not the only ones but that is how I learned to do it) vintage from just after the Tri-5s to at least through the '60s, where the clutch cross-shaft would fall off or the motor mounts would go south suddenly, there isn't much reason to learn how to do it.
(roughly) At a dead stop: shut the engine off then shift the gear box in 1st (keep you foot off the clutch pedal as it isn't going to help at all :evil: ! :lol: ) then, when ready, start the engine in gear and you will move forward. When shifting you slightly let off on the throttle and pull the trans into neutral (it is kind of the same as but in reverse of "double clutching"... in some ways) then let off on the engine RPM some more so that when engine speed and gear box speed match or close to it, you can pull the trans into the next gear in the gear box. Once you have done this continue on through the gears until the next un wanted stop (unless you are finally home or have a heart attack) then pull the gear box into neutral to stop then turn off the engine (I don't recommend turning off the engine to stop as that can end up with potential problems. Repeat the process if needed! Also, you want to be able to time things so you don't have to stop all the time. I once had to drive close 30 miles via. ground streets through Seattle and even back then there was a lot of stop lights; now... phew!
I learned this with cars with non-syncro first gear so I am not sure if you can put the box into first gear with the car slightly in motion. I still wouldn't recommend it though as a ticket is now almost as much as a new transmission :wink: .
This requires keeping your mind on what is going on around you and what you are in the process of doing as you are now handicapped in panic situations. Its not hard... just "difficult" until you have done it enough times. It is hard to say not to learn it 'cause as soon as I say don't someone (such as clonebug' sudden problem) will have a reason to do it.
Clonebug
Post by Clonebug » Sat Jul 14, 2018 11:52 am
I work in construction and drive a dump truck to haul my machine to and from the jobs...The only time I use the clutch in the truck is to take off from a standing start. It has 18 speeds and I shift without the clutch all the time so doing on the buggy isn't too difficult.
On the way home we just took a route where we didn't have to stop completely to get home.
