Fuel Systems that Feed our Turbo powered mills! (GALLERY)
Moderator: seabeebuggy
Muffler Mike
Re: Fuel Systems that Feed our Turbo powered mills! (GALLERY
Post by Muffler Mike » Tue Apr 10, 2012 1:39 pm
Don't remember if I shared this before but a while ago I modified a stock tank. Hold 2 gallons and traps fuel at pick up during acceleration
Wally
Post by Wally » Sun Apr 15, 2012 12:09 pm
Subtle!
marzano
Post by marzano » Tue Apr 24, 2012 12:27 pm
Kalle wrote:Before I installed the Aeromotive pump I used to have a Walbro GS340 (255l/ph) in my tank. Quiet, small and light but it did not supply enough fuel:
Same fuel lines as I`m using on the Aeromotive pump.
Best rgs
BeetleBug
So great!
People, where can I find it?
marzano
Post by marzano » Wed Apr 25, 2012 12:39 pm
Ok.. I found
GPA-Series Fuel Pumps
[]s
fastvwman
Post by fastvwman » Mon May 28, 2012 9:33 am
MarioVelotta
Post by MarioVelotta » Mon May 28, 2012 3:28 pm
Sexy, but that spring looks like it would help hold it full open also :)
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
fastvwman
Post by fastvwman » Mon May 28, 2012 4:06 pm
the spring helps keep it all the way open or closed. instead of halfway accidentally. :)
Marty
Post by Marty » Wed May 30, 2012 11:54 am
fastvwman wrote:the spring helps keep it all the way open or closed. instead of halfway accidentally. :)
EXACTLY!
MarioVelotta
Post by MarioVelotta » Wed May 30, 2012 12:37 pm
I guess I've never wanted a spring to hold my throttle wide open. Am I alone here?
fastvwman
Post by fastvwman » Wed May 30, 2012 4:50 pm
MarioVelotta wrote:I guess I've never wanted a spring to hold my throttle wide open. Am I alone here?
thats the fuel pump shut off. NOT the throttle. :lol:
MarioVelotta
Post by MarioVelotta » Wed May 30, 2012 4:58 pm
Haha! Got me good :)
Fiatdude
Post by Fiatdude » Wed May 30, 2012 10:16 pm
I put some bungs on the bottom of the tank then put the pump up front -- 100 mic prefilter there's a 10 mic hidden back under the tank
Hard lines ran to the back
turboboy
Post by turboboy » Mon Oct 15, 2012 8:14 am
Howdy
So guys what you recommend for a draw through for a 250 to 300 hp motor
Holley red or blue pump or something similar and quieter would be nice ?
pressure reg . just the standard dead head or bleed off style
cheers
Rich
Fiatdude
Post by Fiatdude » Mon Oct 15, 2012 10:24 am
Damn -- Whe you look at Marty's stuff, it makes mine look like chit , so what do you do -- you go buy some of Marty's stuff LOL
Still cleaning things up after fabing them up but basically
2 -5/8" fuel lines back to front
Front cell with pumps and filters
Marty's stuff and my chit LOL
Devastator
Post by Devastator » Mon Oct 15, 2012 10:27 am
turboboy wrote:Howdy
cheers
Rich
EFI?
Devastator's Build Thread
Sandrail
2276 ACVW
MS2Extra EFI W/spark
T3 Turbo making 10 lbs boost
Burning E85
going fast enough."
Mario Andretti
