250HP 1600dp
Moderator: seabeebuggy
Re: 250HP 1600dp
Post by Chip Birks » Wed Aug 31, 2016 8:27 pm
I need to do the same with mine. Got most of the parts. Just need to get it together. Reports like these keep me motivated.
madmike
Re: 250HP 1600dp
Post by madmike » Thu Sep 01, 2016 6:29 am
Awesome 8) 8) 8)
mactaylor
Re: 250HP 1600dp
Post by mactaylor » Wed Nov 23, 2016 12:19 am
Hey kalle, If you don't mind me asking what is your header diameter? I have read the whole thing a few times but it still eludes me!
Kalle
Re: 250HP 1600dp
Post by Kalle » Fri Nov 25, 2016 6:22 am
mactaylor wrote:Hey kalle, If you don't mind me asking what is your header diameter? I have read the whole thing a few times but it still eludes me!
It is, as many other things on my engine, way too big: 1 3/4" and with a T4 flange :D I used the header from my 2332ccm.
-K-
Re: 250HP 1600dp
Post by Chip Birks » Fri Nov 25, 2016 11:04 am
Any idea what your pre-turbo back pressure looks like?
mactaylor
Re: 250HP 1600dp
Post by mactaylor » Fri Nov 25, 2016 3:18 pm
Thanks Kalle!
Kalle
Re: 250HP 1600dp
Post by Kalle » Mon Nov 28, 2016 4:10 am
Chip Birks wrote:Any idea what your pre-turbo back pressure looks like?
Actually no but I do believe it is quite OK. I base this on the response when I want to increase the boost. I`m mostly outside the area where the turbo is really starting to pick up hence why it responds so positive at higher boost. Base pressure (wastegate) is currently 26 psi.
I would also like to inform you all that I sold the car turn-key this weekend. I know that the new owner will take good care of it and also drive respectfully which is important to me.
A big thank you to the thread owner for allowing me to post my updates here! And a big thank you to everyone that have asked questions. Keep them coming and I will do my best to answer :)
-K-
Clonebug
Re: 250HP 1600dp
Post by Clonebug » Mon Nov 28, 2016 9:08 am
:shock: :shock: :shock:
Say it isn't So!!!!!!!!!!
Are you getting out of turbo VW's or just on to bigger and better ones???????
MarioVelotta
Re: 250HP 1600dp
Post by MarioVelotta » Tue Nov 29, 2016 9:50 am
Well you certainly made an impact around here Kalle, thanks for all the info you have shared!
I almost have a short block for mine, I know Chip Birks is working on his as well and Clone has been boosting on his for some time now at 20+ putting a smack down on every car that tried to play :twisted: My hope is that I am caught up enough at the shop by January to take advantage of the slow period to work on my car again. It's hard to move a business forward when you aren't present in the local scene :cry:
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
petew
Re: 250HP 1600dp
Post by petew » Tue Nov 29, 2016 4:36 pm
Hey Kalle, what are you up to next? Gotta another car project in mind?
Kalle
Re: 250HP 1600dp
Post by Kalle » Wed Nov 30, 2016 5:07 am
Thank you guys!
I can tell you that there is NO drama involved with my decision to sell my 67. It is just a time for everything in life and now it was time to do this. Together with the car and the trailer the new owner also got all the parts needed for the MK II version of the mouse engine:
- Thick wall AA 92/94 barrels
- NOS Mahle 92mm pistons
- CB Mini Wedgeport heads with 42x37 valves
So basically going from a 1641ccm to 1835ccm. I have informed the new owner about this thread and I will ask him to present himself.
Other projects? Well.. I have this waiting for me in the garage;
And together with parts for a 2165ccm engine. For the time being NA but perhaps later...........
Please keep this thread alive with your off-the-shelf-cheap-parts high HP mouse engines! I really look forward to reading about them and looking at your pictures. Who will be the first to reach 125hp per barrel? I think it possible!
Best rgs
Kalle
saltgrinder
Re: 250HP 1600dp
Post by saltgrinder » Wed Nov 30, 2016 7:29 am
Ooo yeah , I like the look of that
loVol
Re: 250HP 1600dp
Post by loVol » Wed Nov 30, 2016 10:50 pm
Been following along this thread the whole way through, Great to see how you were able to get so much power out of a mouse engine!
Would you be able to tel me what model of PWR intercooler you used? I'm going to use one on mine, just have to get the right size!
Kalle wrote: This is my plenum and intercooler. It is very quick and easy to remove from the engine and it does look dull after a season of racing;
And from a different angle:
I`m very happy with my PWR intercooler. Yes they do cost a fair bit more compared to the average China ones but I believe you get what you pay for.
Cheers for any help.
Kalle
Re: 250HP 1600dp
Post by Kalle » Thu Dec 01, 2016 6:36 am
loVol wrote:Been following along this thread the whole way through, Great to see how you were able to get so much power out of a mouse engine!
Thanks and of course I can tell you what model I used. You can find it here:
http://www.chargecooler.co.uk/index.php ... cts_id=194
Please not that I did shorten mine a bit.
My water/ice tank is 25 liters and placed in the spare wheel well up front and I`m using a Bosch water/intercooler pump to circulate the water. You will notice a huge diffence in your IAT (Intake Air Temperature) between using only water, water/ice and water/dry ice.
-K-
Torgeir
Re: 250HP 1600dp
Post by Torgeir » Fri Dec 02, 2016 7:06 am
Hi everybody.
Sorry for my late reply after Kalle informed me of this thread, but it took me a while just to get through the all of the 45 pages so far...
I must admit that I was probably as shocked as you guys to get the call form Kalle asking me i if was interrested in bying the car.
Kalle and me go way back, and i have followed the development of the car form when it came to Norway, so it was quite an easy decision to make, but i insisted he use the following weekend after we agreed to make shure it was the right thing to do..
For me it was a winn, winn either way , because I allso would have loved to see Kalle evolve the car/engine even further. Hopfully I will be able to continue the development, but i think at least we will use the following season to get to know each other. Safe to say thet the driver probably neads more updates than the car, as it has been a good couple of years since driving a properly hot vw..
Kalle has kindly offered his support with getting familliar with the setup, and further development.
Will try to continue updating like Kalle has, and if there is anything I can contribute with regarding setup or solutions I would be glad to share. I assume that Kalle will continue follow this thread so i know he will probably give answers on the current setup, and i can help if pictures is neaded, and update on any developments.
Torgeir
