250HP 1600dp
Moderator: seabeebuggy
WickedWagens
Re: 250HP 1600dp
Post by WickedWagens » Fri Dec 29, 2017 1:33 pm
I'm just starting mine. 66x85.5 I should have gone 64x87 but the crank was a trade so I can't complain. Turbocharged for land speed racing at the Bonneville salt flats.
1968 Ghia Land Speed Car
G/CFALT 106.643 MPH 8/2016
G/CGALT 113.131 MPH 9/2016
G/CBGALT 134.606 MPH 8/2017
G/CBFALT 146.715 MPH 8/2017
G/CBGC 158.242 MPH 9/2017
Clonebug
Re: 250HP 1600dp
Post by Clonebug » Fri Dec 29, 2017 2:03 pm
Oh come on Wicked.........no teasing!!! :lol:
What is your boost target, rpm, fuel supply, hp target and all that other good stuff we need to know?????
WickedWagens
Re: 250HP 1600dp
Post by WickedWagens » Fri Dec 29, 2017 5:41 pm
I'm hoping for around 20 lbs boost, 7000 rpm, and enough HP to go 150+ MPH. I don't know if I'm going to try a DHLA 40 or a 2 barrel holley blow through.
Clonebug
Re: 250HP 1600dp
Post by Clonebug » Fri Dec 29, 2017 6:39 pm
20 lbs boost and 7000 rpm with 92 ci. will get you 240 crank hp according to my favorite calculator.
You will need 26.4 lbs/min air or 327 CFM to accomplish that.
That is with the VE down to .89 which is corrected to match my engine output. YMMV
You'll need a good intercooler to keep your IAT's in check depending on how hot it is there...I used a default of 130 degree IAT's to get that flow.
I would think WI might be a good add on to keep your IAT's in check....just carry enough to stay on boost that long.
petew
Re: 250HP 1600dp
Post by petew » Fri Dec 29, 2017 7:38 pm
Nice. Who made that crank up?
WickedWagens
Re: 250HP 1600dp
Post by WickedWagens » Fri Dec 29, 2017 8:11 pm
It’s a DPR crank.
Off Topic
Great. 225-240hp should make my goals for the speeds I want.
buguy
Re: 250HP 1600dp
Post by buguy » Sun Dec 31, 2017 9:40 am
I don't know how much difference it would make but a 1600 is 97 ci not 92.
Re: 250HP 1600dp
Post by Chip Birks » Sun Dec 31, 2017 10:48 am
66x85.5 isn't a 1600
buguy
Re: 250HP 1600dp
Post by buguy » Sun Dec 31, 2017 11:20 am
Oh! I just saw 1600 in the title.
MarioVelotta
Re: 250HP 1600dp
Post by MarioVelotta » Sun Dec 31, 2017 12:53 pm
I want to change the title of this post and am looking for input.
Current Name:
250HP 1600dp
Proposed:
250HP+ from a Mouse Motor
250HP+ from 1500cc - 2000cc
Looking for other options and opinions before I make the change :)
2018 will be the year my Mouse gets put together!
Happy New Year :D
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
WickedWagens
Re: 250HP 1600dp
Post by WickedWagens » Sun Dec 31, 2017 2:43 pm
I would say keep it mouse motor. 1641cc limit or something. I started my own build, but I will add highlights in here.
Re: 250HP 1600dp
Post by Chip Birks » Sun Dec 31, 2017 3:08 pm
Mighty Mice!
buguy
Re: 250HP 1600dp
Post by buguy » Sun Dec 31, 2017 3:49 pm
I always think of anything under 1776 as a mouse! Find or sketch up some ideas and I will see about getting some stickers made!
Clonebug
Re: 250HP 1600dp
Post by Clonebug » Sun Dec 31, 2017 8:13 pm
Me me me!!!!
Under 1700 cc's please!!!!!
MarioVelotta
Re: 250HP 1600dp
Post by MarioVelotta » Sun Dec 31, 2017 9:12 pm
For me, a mouse is under 100ci. 1641 is really close but over. The 11,000 rpm 1776 motor from JPM is considered a Mouse by most.
