250HP 1600dp
Moderator: seabeebuggy
Clonebug
Re: 250HP 1600dp
Post by Clonebug » Mon Jan 01, 2018 1:44 am
Off Topic
So at at 102 cu I am out.........
ToRy 70
Re: 250HP 1600dp
Post by ToRy 70 » Mon Jan 01, 2018 2:13 am
Clonebug wrote:
Off Topic
I think 1641 should count.
1641 cubic centimeters =
100.14 cubic inches
Sent from my LG-H932 using Tapatalk
buguy
Re: 250HP 1600dp
Post by buguy » Mon Jan 01, 2018 10:51 am
He is 1679 I believe. 102.45ci
Wally
Re: 250HP 1600dp
Post by Wally » Mon Jan 01, 2018 11:06 am
So what would you call 1200 cc’s then? :-)
buguy
Re: 250HP 1600dp
Post by buguy » Mon Jan 01, 2018 2:34 pm
Mini mouse!
Wally
Re: 250HP 1600dp
Post by Wally » Tue Jan 02, 2018 2:25 am
or just plain 'crazy' LOL!
Kalle
Re: 250HP 1600dp
Post by Kalle » Mon May 14, 2018 4:30 am
MarioVelotta wrote:
Sun Dec 31, 2017 12:53 pm
2018 will be the year my Mouse gets put together!
Hi Mario,
How is it going with your mouse engine?
Best rgs
Kalle
MarioVelotta
Re: 250HP 1600dp
Post by MarioVelotta » Mon May 14, 2018 10:38 am
Hi Mario,
Best rgs
Kalle
Well, I kinda got sidetracked with a supercharger on my stock 1600. I seemed like a good idea since everyone else has one :lol:
Since then I've pulled the motor to have my transmission serviced. It's back I just have not reinstalled it. Once I do that I can get some SC dyno numbers, I'm really interested in the torque as it's making 9psi at 2000rpms. It's like driving a small 2L :D
After I get the dyno numbers I can finish assembly of my turbo 1600. I needed to have the case re-machined as 3 of the bearings were too tight and make a final decision on the cam to use with my Los Panchitos.
I've got a good assortment of cams to choose from but I' think it needs to be pretty aggressive to keep up with the custom cam Chip got from Paradise.
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
Re: 250HP 1600dp
Post by Chip Birks » Mon May 14, 2018 1:28 pm
Hi Mario,
Best rgs
Kalle
Bahahaha! You've got much better heads and are much better behind the laptop than me! I don't think my little VWP cam is gonna make all the difference! E85 might help me though, just a little.
Kalle
Re: 250HP 1600dp
Post by Kalle » Tue May 15, 2018 8:28 am
Perhaps not useful info at all but I ran a very mild cam on my 1641ccm engine. Basically a W110 on 112 lobes by JPM which again allowed me to use 1.5 rockers. Not a lot of lift even with the 1.5`s. Changed the CB650 springs every second year/season even though I was not forced to since they did not loose a lot of tension.
Best rgs
Kalle
buguy
Re: 250HP 1600dp
Post by buguy » Tue May 15, 2018 11:21 am
Do you have any numbers or timeslips with that engine?
Wally
Re: 250HP 1600dp
Post by Wally » Tue May 15, 2018 11:38 am
I think all data and info are further back in this thread. Kalle shared everything afair :wink:
Re: 250HP 1600dp
Post by Chip Birks » Tue May 15, 2018 12:52 pm
Best rgs
Kalle
Thats crazy! Mine isn't crazy wild, definitely bigger than a w110 though! Just goes to show, an efficient turbo and good fuel make all the difference.
Kalle
Re: 250HP 1600dp
Post by Kalle » Wed May 16, 2018 1:08 am
Hi buguy,
Here you go:
- 1641ccm
- Mahle barrels and pistons.
- Scat 5.5 rods with Scat 625 rod bolts.
- Home ported CB044 heads with 650 springs.
- DPR 69mm crank.
- JPM version of a W110 cam.
- JPM Alu pushrods.
- Precision 5862 turbo with a T4 flange AR58.
- Custom exhaust and intake system using a PWR water to air intercooler and manifolds from vwspeedshop UK.
- E85 with a Aeromotive Eliminator in-tank fuel pump.
375 whp at 26psi and a fair bit above 400whp at 35 psi and 10.41/137mph in a heavy 67 but more importantly: really reliable with minimum maintenance and PLENTY of fun! Fully streetable and only minor issue was to get high enough oil temperature. It looks like this:
And Chip, I agree! Feel free to use a high lift and aggresive cam but you will have to leave with that choice afterwards and adapt to it with frequent valve spring checks and higher spring pressure - more wear and tear.
-K-
buguy
Re: 250HP 1600dp
Post by buguy » Wed May 16, 2018 5:32 am
Damn!
