Problem of the day. Post it up!
Moderator: seabeebuggy
madmike
Re: Problem of the day. Post it up!
Post by madmike » Tue May 03, 2016 6:27 am
So true, just to freak out the 'Chevy' boys :lol: :lol: :lol:
MAA
Post by MAA » Sat Jun 11, 2016 4:30 am
Quick question I haven't been able to find the answer on here. Where are you guys getting your oil input line from?
madmike
Post by madmike » Sat Jun 11, 2016 5:44 am
I use a -3 stainless steel brake line screwed into a T on the case, where the stock oil sender is :wink:
madmike
Post by madmike » Tue Jul 19, 2016 6:32 am
It was the 'Wastegate ' giving me grief :roll: now to fine a good one :lol:
Post by Chip Birks » Tue Jul 19, 2016 11:02 am
madmike wrote:It was the 'Wastegate ' giving me grief :roll: now to fine a good one :lol:
MarioVelotta wrote:Turbosmart :lol:
I share Mario's opinion. I have a TiAl and Turbosmart. Both very good gates in my opinion. The TS is tiny, and had a very nice spring clamp system.
madmike
Post by madmike » Wed Jul 20, 2016 7:11 am
Thanks Guys,,
chriswillrise
Post by chriswillrise » Thu Dec 08, 2016 10:31 pm
Ok, new motor got everything buttoned up but cannot get the car to start without carb spray or holding my hand over the carb. holley 2 barrel prepped by aj sims. no vacuum leaks i can find. iver tried everything i can think of and need some help. It runs great spraying carb spray down the carb haha
madmike
Post by madmike » Sun Dec 11, 2016 6:33 am
Hey Cris,with my sidedraft's I pump it a few times and it eventually starts up :lol:
after it warms it starts right up :wink: does yours do that too?
madmike
Post by madmike » Wed May 24, 2017 6:28 am
Start up with the Demon 4 barrel is instant :wink: one pump it Firers right up 8)
Ron Perkins
Post by Ron Perkins » Mon Jun 19, 2017 1:39 pm
Had an oil leak that turned nasty when I switched to Royal Purple. Looked like it was coming from the flywheel seal but it was on top of the case, thought it was coming through that inspection hole or whatever it is. Pulled the engine, replaced it, put it back in, lead worse than ever. Had to be coming from the shroud oil cooler. Pulled just the shroud, PITA with the turbo set up on. Put a new cooler in, so far so good. Now if it would stop raining in southern florida. 4th week of rain, beginning to remind me of summer in Michigan..only a lot hotter.
Post by Chip Birks » Sat Jul 08, 2017 4:51 pm
Just spent the last week doing a quick refresh on my motor, got it all installed yesterday, took pretty much all day. Managed to fire it up today, and after swapping rear tires and lowering it off of the jackstands i noticed a new puddle under it, looked up to see the source and could see a drip hanging from the flywheel side of the motor. No racing for me tonight!
clintonddk
Post by clintonddk » Tue Aug 01, 2017 7:55 am
Will changing fuel also change boost pressure?
seabeebuggy
Post by seabeebuggy » Sun Oct 08, 2017 9:11 pm
No but changing fuel to a higher grade of octane can let you run more boost.
