Turbo charging 66 square
Moderator: seabeebuggy
Clonebug
Re: Turbo charging 66 square
Post by Clonebug » Sun Jan 13, 2013 11:18 am
Do you have a CW crank and everything balanced or is it stock internals like mine???
Corysvdub
Post by Corysvdub » Mon Jan 14, 2013 1:21 am
Clonebug wrote:Do you have a CW crank and everything balanced or is it stock internals like mine???
Chromoly CW crank and balanced internals
Type 3 Subaru powered EJ25
T-34
Post by T-34 » Wed Mar 27, 2013 4:59 am
Sweet build.
Did you have to modify the Type 3 throttle body to make is boost ready?
http://vdubber.com - Aircooled blogs, builds and banter.
Corysvdub
Post by Corysvdub » Wed Mar 27, 2013 11:45 pm
Honestly I haven't done anything to the throttle body. Didn't even check if it leaks, ran it n/a for a bit before I added the turbo. Building a new center section right now with a larger throttle body.
Corysvdub
Post by Corysvdub » Thu Mar 06, 2014 12:34 am
Wow, it has almost been a year since I said I was building a new center section. Well it has been done, just haven't posted any pics.
Corysvdub
Post by Corysvdub » Thu Mar 06, 2014 12:39 am
Here is a comparison between the stock throttle body and the new to me throttle body I will be attaching to a new center section. Stock one is about 40mm
Corysvdub
Post by Corysvdub » Thu Mar 06, 2014 12:44 am
Finished center section.
Sorry I didn't take any build process pics, was kind of trying to finish it quickly. Just recently added a meth injection kit about a week ago too. :twisted:
Corysvdub
Post by Corysvdub » Thu Mar 06, 2014 12:55 am
Where are you guys injecting your water/meth? Is it before the throttle body or after?
I was having acceleration triggers on my tps without even touching the pedal and I thought It could be because the water/method was blowing past the butterfly shaft and right into the tps. I was really erratic had to calibrate my tips several times and the ADC count just kept getting lower and lower until it was at about a 2 or 3.
I checked all the wires and they appear to be good with no breaks or loose connections, so I decided to take the throttle body off to check the tps and sure enough I had blue fluid dripping out of it. Tried blowing it out and re attaching it but I think the damage is done and now I need to order a new tps. :cry:
Clonebug
Post by Clonebug » Thu Mar 06, 2014 7:09 pm
I inject before the throttle body and haven't had a y problems yet.
I will probably change it to after the TB with the new manifold though.
yvre
Post by yvre » Fri Mar 07, 2014 2:20 am
When we injected water before the throttle body on the supercharged drag car we began to have problems with corrosion on the throttle shaft. The throttle would not want to come all the way back, leaving us with a super high idle on the starting line.
Post by Chip Birks » Fri Mar 07, 2014 2:45 am
Mine is setup to spray before the turbo, and after the intercooler, which is post throttle body on my setup. I have never actually used the system though. Boost hasn't been high enough to detonate with a good fuel mixture, yet.
Corysvdub
Post by Corysvdub » Tue Mar 25, 2014 12:12 am
Fastest time slip to date for this motor. I am very happy with how it runs for a smaller motor, I asked the guy what size was motor was in his car for a comparison. Got three practice runs in before eliminations, then I broke something in the transmission after/during my burnout.
I got a tow home that day and proceeded to take this out.
Corysvdub
Post by Corysvdub » Tue Mar 25, 2014 12:16 am
Chip Birks wrote:Mine is setup to spray before the turbo, and after the intercooler, which is post throttle body on my setup. I have never actually used the system though. Boost hasn't been high enough to detonate with a good fuel mixture, yet.
Ya lucky you Chip :D Wish I could say the same, but they don't make squishies in 88mm :P
Clonebug
Post by Clonebug » Tue Mar 25, 2014 11:18 pm
Nice Run!!!
That's pretty close to my Buggy run on my Iphone Dyno.
You have a better 60 ft time. Mine was 2.24 sec. at 27.4 mph.
Do you have any wheel spin on launch???
Our 330 is within a 0.01. Mine was 6.07
My 1/8 mile was 9.17 sec @ 78.4 MPH
How much boost are you running and what are the IAT's at said boost???
Your car must weigh almost 2300# correct??
Corysvdub
Post by Corysvdub » Wed Mar 26, 2014 12:19 am
I do have some wheel spin. I am running 15# of boost at the moment, I haven't even checked my logs for the temp on those runs yet.
I was mostly trying to tune it a little leaner, it was very rich when the water/meth kicked in around
10-11 to 1 Afr.
Yes it weighs somewhere around there, I had my rack, tools, cooler, and a spare in it as well. The 17 inch wheels probably don't help much either.
