Turbo charging 66 square
Moderator: seabeebuggy
Clonebug
Re: Turbo charging 66 square
Post by Clonebug » Wed Mar 26, 2014 7:34 am
Corysvdub wrote: The 17 inch wheels probably don't help much either.
I have 275/60-15's in the back and they are 27 inches tall which raises the gearing a fair amount compared to stock tires. Your tires are probably larger diameter than stock too which raises your gear ratio.
I do have the 4.12 ring and pinion.
I was at 4000 rpm at 99.2 mph in the quarter which probably affected my times a bit. It makes for a great driver at cruise though and putting smaller tires on it is not worth it to gain a little E.T unless I tried it once or twice.
Plug your numbers into a hp calculator to see what you come up with........I'm interested to see how close we will be.
What size valves do you have and what heads???
Corysvdub
Post by Corysvdub » Wed Mar 26, 2014 12:40 pm
I will do that hp calculator later, as well as check the iat temps for you.
My transmission has a 3.88 R&P
The heads I believe are CB 044's with the 42x37 valves.
Type 3 Subaru powered EJ25
Corysvdub
Post by Corysvdub » Wed Mar 26, 2014 11:36 pm
The intake temp at 15 psi was 189 degrees. My iat sensor is before the water/meth injection, so I don't see the changes in temp anymore since I moved the nozzle.
I was seeing around 135 degrees when the nozzle was before the sensor.
Clonebug
Post by Clonebug » Thu Dec 25, 2014 10:41 am
Corysvdub wrote:The intake temp at 15 psi was 189 degrees. My iat sensor is before the water/meth injection, so I don't see the changes in temp anymore since I moved the nozzle.
Sorry for such a late reply to this post....I was checking up on your build.
Your compressor temps are pretty close to what I am showing with mine.
186 at 13 lbs. no spray.
144 at 17 lbs with water/meth injection.
What is the update on your build now Cory???
Are you running and driving??
Corysvdub
Post by Corysvdub » Thu Dec 25, 2014 2:59 pm
Yes clone, I am up and driving. I have purchased a new turbo to install "larger " just haven't had the time to install it. Been working on my interior of my bus and working a lot.
I was having detonation issues with the motor, meth solenoid wasn't opening. Fixed that and things are better now. Can't wait to install this new turbo and tune for it.
Thanks for checking up on my build, I enjoy reading yours. Have a Merry Christmas
Clonebug
Post by Clonebug » Thu Dec 25, 2014 10:16 pm
Oh come on now Cory....... :lol:
Don't be teasing us this time of year when we are looking for some build action.......
What turbo did you get????
Corysvdub
Post by Corysvdub » Fri Dec 26, 2014 1:43 am
It is a t3 with a .36 housing, can't wait to install it
Clonebug
Post by Clonebug » Fri Dec 26, 2014 11:56 am
Very nice!!!
I see you are running 1800cc's....what did you build for an engine????
No more 1679cc????
Corysvdub
Post by Corysvdub » Fri Dec 26, 2014 10:36 pm
Clonebug wrote:Very nice!!!
No more 1679cc????
Nope no more 1679cc, I had to stroke it. I figured why not since the crank was the same price. I also have some forged 88mm pistons in the motor now since those cast ones completely destroyed the whole block and internals. Went with another Engle 100 cam, scat lube a lobe lifters with the Bob Hoover mod along with the case as well.
I was planning on changing the turbo before the catastrophe happened. That just added more time and money before I could purchase the turbo. Should see it installed next month. "I hope" :D
Corysvdub
Post by Corysvdub » Fri Dec 26, 2014 11:11 pm
Also forgot to add I might be pulling the motor to change / upgrade the pressure plate, my stage 1 is slipping in third gear. I might have the cable a little too tight. We will see.
panel
Post by panel » Sun Dec 28, 2014 1:48 am
Got any good 3/4 views of your very nice car ?
Subaru JDM EJ20 Turbo bus
Corysvdub
Post by Corysvdub » Sun Dec 28, 2014 3:01 am
panel wrote:Got any good 3/4 views of your very nice car ?
Corysvdub
Post by Corysvdub » Sun Apr 01, 2018 2:34 pm
Turbo 1800cc is for sale, if anyone is interested let me know 👍https://www.thesamba.com/vw/classifieds ... id=2146780
Clonebug
Post by Clonebug » Sun Apr 01, 2018 4:30 pm
Come on Cory....no pics of the upgrade????? :shock: :( :wink:
Corysvdub
Post by Corysvdub » Sun Apr 01, 2018 5:43 pm
Lost pics I used to have on my phone so I'm doing screenshots
