Fastbacks bus! WOW
panel
Fastbacks bus! WOW
Post by panel »
Have you guys seen these pics? I've seen some pics of this thing lifting a wheel in the corner :shock:
http://www.youtube.com/watch?feature=pl ... CIPo79DHlA
turbobaja
Re: Fastbacks bus! WOW
Post by turbobaja »
Why are we just now seeing this thing :?:
Looks freakin' awesome!!!
Karl
DON'T QUIT
fastback
Post by fastback »
oh..!
thx guy's .i see The Speedhunters guys have been at the Norwegian "Gatebil" festival last weekend :)
Typ 11 Beetle
Post by Typ 11 Beetle »
Fastback ,
please show us more pic´s of your bus!!!
brookester
Post by brookester »
What kind of powerplant is that?
fastback
Post by fastback »
engine is a 2.4L Wasseboxer turbo megasquirted 571 RWHP :)
fastback
Post by fastback »
fastback
Post by fastback »
Clonebug
Post by Clonebug »
How much boost is it running????
That's a lot of hp from 2.4 liters....
Wally
Post by Wally »
Wow! 571 RWHP now?!! :shock:
That is indeed awesome!
(stupid max 800 pixels wide STF thing)
shag55
Post by shag55 »
Vary nice Fasty!
Agreed. Hard to post any pics anymore with this size restraint.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
[email protected]
Facebook at SL 1 racing
shag55
Post by shag55 »
What size turbo? How much boost? Is lag an issue on the track?
What's next?
[email protected]
fastback
Post by fastback »
The turbo is a Precision with a ~60'ish compressor wheel and a ~65'ish turbine.
boost is pretty stable on 1.2 bar(wastegate spring pressure) up to 6500 and from there it creeps up to 1.75 bar @ 7500 where i stopped on the dyno last time.
before i have had it up in 7650 on the dyno with climbing HP numbers and on the track 8200 RPM without any signs of the engine loosing power...
also with backpressure 0.7bar under boost pressure i have more horses waiting :)
I'ts not laggy, but my grandpa style gearchanges may give an impression of that but the few times i changes gear fast it's fast on boost again.
since i have spent 3 years collecting parts and saving money and building it , i will have some time on the track with these numbers to get some quality time with it :D in the end of the season my goal is to exceed 2.0bar and go 8000+ RPM AND start using the boost control to get boost form lower RPM's
I left the boost creep as it is , since it gives the engine the extra punch on the top end . it's like a porsche GT3 on crystalmeth!
fastback
Post by fastback »
a funny story during testing , i actually blew the wall out of the combined plenum and IC's... yes i had been a coward with the amp's on the welder and not calculated the forces on the weld. it actually is almost 1000kg force on the wall at 1.5 bar boost.!! :shock:
so i had to crank up the amp's and made a lot of reinforcements inside the plenum :)
fastback
Post by fastback »
so i took some stock 1600 pushrods and made reinforcements .
it does not seem to influence airflow :)
