100 Cubic Inches of Fury!
Moderator: seabeebuggy
Post by Chip Birks » Wed Dec 12, 2012 3:37 am
I don't really know what's wrong with me. Winter is here and I'm bored. My bug is parked in the garage, and for the first time in years I can go out there and fire it up whenever I want. For some reason that is just not good enough. I've been collecting parts over the last year or so to build an evil mouse motor, and I may just make that jump while the snow is flying. Last year all of my efforts were focused on getting the big one together, as well as sorting out all of the various fab jobs required to turn 1000 boxes of stuff into a running and driving car. This year I can focus on the little guy.
The basic plan is to basically swap the long blocks leaving almost everything else in tact. A turbo change will probably be in order as well, but I have options there too. This motor will more than likely be an E85 gulper since it will be seeing a lot of boost. It'll also get a nice spray of water/meth injection to ensure that detonation stays far away.
As of right now that is all I have to say. I'll update this thread as I get bits and pieces together. This little motor will be a "sweep the floor" type of arrangement. Should be a fun build.
Mario, is there room in the 1600 Club for one more?
MarioVelotta
Re: Project "done" now what...
Post by MarioVelotta » Wed Dec 12, 2012 3:57 am
Ha! There is room for as many that want to play. Right now I honestly don't feel like my car will ever run again.
Mario@thedubshop.net
2276 Turbo - 92 Octane
11.537 @ 115.74mph - 15psi
1600 S.C. - 92 Octane
15.47 @ 83mph - 13psi
1600 NA ITB - 18sec :lol:
Vee Dub Nut
Post by Vee Dub Nut » Wed Dec 12, 2012 7:05 am
Chip Birks wrote:I don't really know what's wrong with me....
I know the feeling.. my car is on what revision now? :roll:
Sounds like a fun project.. keep us posted!
Fightin' Texas Aggie Class of 2006
67 Beetle
madmike
Post by madmike » Wed Dec 12, 2012 8:55 am
You are not alone :wink: Winter sux :evil: I'm too busy in the summer(3months) so I'ts build time in the off season :D
Eaallred
Post by Eaallred » Wed Dec 12, 2012 9:46 am
Come work on mine, Chip. Plenty to do over here! haha
Steve Arndt
Post by Steve Arndt » Wed Dec 12, 2012 11:13 am
My squishy engine is done. Now I'm trying to decide if I should swap it out of my baja and install a 2600 T4 I'm building, or just turbo the squishy engine for fun.
Post by Chip Birks » Wed Dec 12, 2012 11:21 am
MarioVelotta wrote:Ha! There is room for as many that want to play. Right now I honestly don't feel like my car will ever run again.
I felt the same way, just keep plugging along and it'll be ready soon enough.
The only problem with winter for me is the cold, my garage is not even sort of warm to work in, it is just isolated from the elements.
Eric, you should move closer to me, then we can work on each others junk much easier :mrgreen: Move fast though, come April-May I'll be needing help with more than the cars...In fact I need to be done with this aspect of the project by then since it will be put on hold once my BABIES get here.
Post by Chip Birks » Wed Dec 12, 2012 11:23 am
Steve Arndt wrote:turbo the squishy engine
YES!!! Probably should do new big chamber heads though, or you'll be pretty boost limited like Stripped.
Eaallred
Post by Eaallred » Wed Dec 12, 2012 7:36 pm
Yea, get all your projects done now, cause it'll be limited after the new arrivals!
If I can source you anything to heat your garage, let me know. I know a guy that can get you equipment for cost. ;)
Steve Arndt
Post by Steve Arndt » Wed Dec 12, 2012 7:43 pm
And he is skinny if you have a tight crawl space...
Post by Piledriver » Wed Dec 12, 2012 8:35 pm
E85 should love the CR...
Eaallred
Post by Eaallred » Wed Dec 12, 2012 8:40 pm
Steve Arndt wrote:And he is skinny if you have a tight crawl space...
LOL, no way. Chip's skinnier than me, er, this guy I know. When I get ready to hire a guy, i'm looking for a skinny fella. haha
Post by Chip Birks » Mon Apr 16, 2018 5:02 pm
Time to bring this one back from the dead. Finally started dusting off the parts I have for this new engine. Excited to move forward!
buguy
Post by buguy » Mon Apr 16, 2018 6:13 pm
Will you use your existing efi stuff or build another unit?
Post by Chip Birks » Mon Apr 16, 2018 7:00 pm
For now I'll just reuse what i can. This new engine will just plug in under everything else. I'll have to change my cast aluminum intake manifolds to some that match the ports of my little heads, but otherwise most everything else should transfer over. It'll get its own pulley w/trigger wheel, and maybe a cam sync. It may also just inherit my small injectors, I got a new set for the big engine, assuming it'll actually run with them installed(they are real big). I'll do a new ecu once I have 2 cars to put the engines in.
