1600 EFI Turbo Build
Re: 1600 turbo EFI build
I never dynoed my 1600 but it never seemed to drop off at 4500. It seemed to keep on pulling and my 1679 definitely will go beyond 5200 if I let it.
My estimate of your hp was pretty close to what you got.....
- MarioVelotta
It would keep going I'm sure, but when the numbers are going down I didn't need to push it.
[email protected]
[email protected]
- Soul
That's not too shabby; roughly 112 hp @ the flywheel.
Try a T25, that'll fatten your TQ curve.
Originally we planned on a T25 for it but a T3 is more cost effective and for a brouder range of customers. Looks like we may have to build a special little T25 for it in the future.
Shag Leone, SL-1 Racing
325WHP and 290TQ @17# on 91oct
383WHP and 324TQ @23psi on 50/50 mix
What's next?
Need a turbo or parts!
[email protected]
Facebook at SL 1 racing
What's next?
[email protected]
What's the spec on this turbo? Perhaps a T3 could still work, using the smallest hot side parts: .36 turbine, small wheel, ect.
Stg1 .36 a/r and 50trim
What's next?
[email protected]
What's next?
[email protected]
- Corysvdub
Have you like looked at the Garrett gt1548 or the gt2052(1) for this build? The flow map for that t3 seems too much for it.
Type 3 Subaru powered EJ25
- MarioVelotta
It was picked for the ease of using it on a larger motor as well. I just thought it might work a little better on this little guy than it did
[email protected]
[email protected]
- Corysvdub
Oh, I see. That turbos flow map would work on something larger a 1776. You don't want to do turbo options on these proposed kits?
I think it has more to do with available headers. There is no 1 3/8" with a T25 flange available. A custom one would add largely to the cost.
What's next?
[email protected]
What's next?
[email protected]
- MarioVelotta
Yeah that was a major consideration. It would be great for a larger package. I just don't have anything like that here to test it with.shag55 wrote:I think it has more to do with available headers. There is no 1 3/8" with a T25 flange available. A custom one would add largely to the cost.
[email protected]
[email protected]
- MarioVelotta
Since I pulled the turbo stuff off. I was ready to try some ITB's
Check that progress here - http://www.shoptalkforums.com/viewtopic ... 6#p1184256
[email protected]
[email protected]
Why did you pull the turbo off?
