New prototype Porsche cooling shroud on 2276cc turbo EFI
- blue thunder
Re: New prototype Porsche cooling shroud on 2276cc turbo EFI
Here are some more pics of the cage I have bent myself (since the cage supplier just keeps on screwing everything up ):
Still alot of work to be done, but I hope to make some good progress in a week (taking some days off )....
Is this Protec shocks?
What model do you use for the rear end?
- blue thunder
Hi Tmatre,
Yes, these are protech shocks. I had them custom made and they just barely fit. I could send you the specs (and drawings with measurements) in a PB if you'd like.
Cheers,
Robin
Cheers,
Robin
- blue thunder
It has been some time since I have posted, as I've had a broken gearbox and some other issues. I have done some testing on Spa Francorchamps race track, some long roadtrips (including freeway @130km/h) and finally did some dragracing in Germany. Though the track was quite slippery (not prepped at all), still managed a 11.6@118mph with a mediocre 1.85 60ft time. Still got the win over a new BMW M5, so quite happy. This was still on WG pressure (15psi) so I still have 7psi to go. Also need to stiffen up the rear suspension, as dragracing needs a bit different suspension settings compared to track and street driving. I also need to replace the 4 thermocouples at the heads, so I can log the data.
https://www.youtube.com/watch?v=FEoISXKboAI
https://www.youtube.com/watch?v=Mcz1BjiwyKY
