Page 14 of 15
Re: 2,23 ltr type 4 turbo build-up
Posted: Sun May 27, 2018 10:49 pm
by Kalle
Happy birthday Wally and congrats with the impressive results on the dyno. There is potential there for whole lot more when you get everything under control and increase the boost.
Take care my friend and enjoy the day and remember: pedal to the metal!
-K-
Posted: Mon Jun 18, 2018 4:06 pm
by Wally
First test runs at our local track and national event at Wanroij, Netherlands. Just a 125meter 'track'.
It was fun nonetheless. Boost set at 0.65 bar :wink:
Good test as some small issues came up, but we drove to and from the event on our own wheels without problems :D
https://youtu.be/mORbikvqoy4
Posted: Mon Jun 18, 2018 6:09 pm
by buguy
Sounds great!!
Posted: Mon Jun 25, 2018 5:55 am
by Udo Airbus
wauw gaaf Walter! Very cool!
Posted: Mon Aug 20, 2018 7:42 am
by Wally
Unfortunately, the one-off cast alu cylinders proved to be too soft/weak as the material was compressed somewhat probably and also the bore openend up top and as a result of this finally a desastrous leak occured, which drew in fresh air on suction and made a torch of the mixture in that cylinder:
Damage is one cylinder, one head and one Raceware stud. Pistons are (fortunately) in great shape however.
All bores had a pretty big taper, so material was obviously not strong enough despite 9mm (!) wall thickess.
The taper also explained the somewhat excessive blow-by I encountered under boost..
New cylinders will be 98mm birals from AA with new regular JE piston rings.
I could order 1 new stud from Raceware (tnx guys!) and Jacob fixed the head: awesome!
The 98mm AA's are just 3,5mm wall thickness, so I am a little concerned there, but 94mm type 1's aren't much thicker afaik, so fingers crossed...
Learned something the hard way, but other (to me new) things in the engine did work out very well, so lets move on!
Posted: Mon Aug 20, 2018 8:02 am
by andy198712
Nasty way to learn :(
When your pushing the design of these engines to new highs I guess you’ll find some limits of certain parts.
Keep up the good work :)
Posted: Mon Aug 20, 2018 8:33 am
by rubenski
I cracked 3 pistons, I know the feeling!
Its a PITA but learn the lesson and move on!
Greetz!
Posted: Tue Aug 21, 2018 10:56 pm
by petew
Ouch!
Posted: Wed Aug 22, 2018 12:14 am
by mactaylor
Tune was fat Wally?
Posted: Wed Aug 22, 2018 6:56 am
by Wally
It was turbo-rich so to speak 😉
AFR was not the issue here..
Posted: Wed Aug 22, 2018 11:03 am
by mactaylor
Thought the lining in the cylinders may have been good enough! obviously not!
Posted: Wed Aug 22, 2018 2:48 pm
by Wally
No, lining held up, that wasn’t the problem either. If the tension between head and cylinder gets less and less, this is what will happen. And it wasnt the studs either. Cause is in my original post before just to be clear on what happened ;-)
Posted: Fri Sep 07, 2018 12:09 pm
by ssrt
How much did you touque those raceware studs?
Posted: Sun Sep 09, 2018 2:35 pm
by Wally
The original value (23 lbs.ft iirc)
Posted: Tue Sep 11, 2018 8:57 pm
by petew
So what's your plan for the rebuild? Iron cylinders? What about Deuz cylinders?
