SOLD - 1600 TURBO + oval + downunder
madmike
Re: NEW plan - 1600 TURBO + oval + downunder
Post by madmike »
8) 8) 8) :lol:
petew
Post by petew »
So today was the first time in ages my wife has been a passenger in the beetle. Just my luck, the passengers side front caliper bracket decided to come loose just in time for that. So instead of picking the other car up from a service easily, I spent an hour, pulling off the front hub and tightening everything back up. Course I didn't tell her what went wrong. She'd never climb in the car again! :D
Post by Chip Birks »
petew wrote: Fri Oct 19, 2018 12:57 am So today was the first time in ages my wife has been a passenger in the beetle. Just my luck, the passengers side front caliper bracket decided to come loose just in time for that. So instead of picking the other car up from a service easily, I spent an hour, pulling off the front hub and tightening everything back up. Course I didn't tell her what went wrong. She'd never climb in the car again! :D
Same thing happened to me one of the few times my wife ever rode in mine!
My wife won't ride with me either and I don't think I have done anything wrong :roll: :lol: … yet. She prefers to drive my Honda Pilot unless the "group ride" has someone else in the Honda.
andy198712
Post by andy198712 »
maybe a bit of lactate may help for future husband/wife outings lol
EDIT wow, auto correct made LOCTITE go to that.... :lol:
Maybe both is correct :lol: . That is a very old pix but we still do group/family rides.
petew
Post by petew »
andy198712 wrote: Fri Oct 19, 2018 9:43 am maybe a bit of lactate may help for future husband/wife outings lol
BAHAHAHAHA! This is a family show! :lol: :lol: :lol:
But yes, I did loctite them :wink:
andy198712
petew wrote: Fri Oct 19, 2018 3:12 pm
:lol:
maybe try the other if that doesn't work for you then!
madmike
Post by madmike »
Yepper , the old days just check out them "dated" MX Boots,Lee :lol: :lol:
madmike wrote: Sat Oct 20, 2018 4:33 am Yepper , the old days just check out them "dated" MX Boots,Lee :lol: :lol:
If you are talking about the white boots my oldest stepson is wearing... he still wears them... just getting broken in. The pix is from the eary 2000s.
petew
Post by petew »
Spent a few hours working on this again this arvo...
I added a drain to the bottom of the breather box. A small piece of oil line runs back behind the alternator stand and then dumps into one of Mario's dizzy-delete bungs. It wasn't particularly hard work, but it ticks me off that CB sells this thing that leaks, even when you use RTV on the seal. In fact it seems to just leak everywhere. It's the second time I've had to pull it apart and try and stop the leak. Next time I'll throw it across the garage and find some other way of doing it. :x
rubenski
Post by rubenski »
Ive heard of that thing leaking alot.
I just run this little bugpack breater, never had an issue with it. Breating from the valve covers and oil fill port.
Verstuurd vanaf mijn SM-A750FN met Tapatalk
madmike
Post by madmike »
Bummer Pete,, have u ever tried Motoseal by loctite?
panel
Post by panel »
Pete......not sure if I have this right but.....looks like you're trying to drain into part of the case but I believe the case will have pressure in it , no ? Crankcase pressure ? I think I have mine there also (Subaru) but it might be something to look at. The fluids will probably drop before the vapours into the case.
What does the top look like ?
petew
Post by petew »
madmike wrote: Sun Oct 21, 2018 5:34 am Bummer Pete,, have u ever tried Motoseal by loctite?
You can't Loctite a rubber seal. BTW, the ports for the breathers are on top. The issue is the oil pools in the bottom there and then leaks out around that edge.
