NEW plan - 1600 TURBO + oval + downunder
Moderator: seabeebuggy
woodsbuggy1
Re: NEW plan - 1600 TURBO + oval + downunder
Post by woodsbuggy1 » Sun Mar 11, 2018 4:25 pm
I have used stock valve covers for 3 years with no problems on my 1776 turbo motor. How do you have the case vented?
Kenric
Clonebug
Post by Clonebug » Sun Mar 11, 2018 4:30 pm
Stock valve covers and bales for me....No leaks unless I don't seat them well.
petew
Post by petew » Sun Mar 11, 2018 5:12 pm
Hmm, maybe that's what I'm doing wrong. And yes, vented out the wazzoo... although I think I could do with more somehow. I looked at a 912 breather can the other day and it's got a massive throat/filter on top of it.
Clonebug
Post by Clonebug » Sun Mar 11, 2018 6:24 pm
All my venting problems were caused by cracked pistons....Once I replaced my P/C's I have not had any issue with venting or breathers again.
I use the stock breather and I put a V-8 valve cover filter on the top with a Tee below going to a homemade road draft tube.
No oil anywhere.........
petew
Post by petew » Sun Mar 11, 2018 8:25 pm
CB, you suck. I have new P/Cs and it's still leaking. :(
In other news, my brake pedal feels like sponge cake. So up on jackstands and angry family members pumping the brake pedal for me. My wife is the best at it, but she hates it more than her sinus problems. Fun times! :D :(
petew
Post by petew » Mon Mar 12, 2018 7:51 pm
Well, good news is, brakes are all bled up again. Had my 14yo daughter help me. Then showed her how the brake system worked and had her put the wheels back on with me. She's pretty great. Told my wife it was, "fun". Wife groaned. :D
petew
Post by petew » Tue Mar 13, 2018 11:01 pm
Just ducked out to the local shops in the beetle to pay a few bills. So I'll stop whining about it. Sure, the idle motor is mucking up and the WB drops out as it drips oil everywhere. But it is fun. And no sooner had I parked at the shops than an old guy in a wheelchair accosted me and told me copious VW tails before I could get to the post office. Hilarious. :D
P.s. and Clonebug, I'm sorry. You don't suck. I was just being obnoxious. :|
panel
Post by panel » Wed Mar 14, 2018 4:14 pm
There's lots of vids out there but you get the idea.
https://www.youtube.com/watch?v=MfTmlOZbXgs
Subaru JDM EJ20 Turbo bus
Post by Chip Birks » Wed Mar 14, 2018 6:46 pm
I have stock covers and bails. 7500rpm, .570" lift, 20+ psi boost. One has a vent in it to be used as a drain for my breather box, my breather has a huge -12AN single connection coming off of the alternator stand, and then just the drain to the valve cover.
petew
Post by petew » Thu Mar 15, 2018 12:13 am
Yeah, cheers guys. I've actually found bleeding like that tends to leave small amounts of air in there. Have someone pump it up hard, while I bleed manually totally gets rid of the air.
Thanks Chip. I think I've got another leak around the deep sump and maybe the stock valve covers too. Failing that, it's rings, which is not terrible, but I'd rather it's not. :(
petew
Post by petew » Mon Mar 19, 2018 5:01 pm
Had the car out yesterday, going off to a mate with a slightly delicate situation. What I noticed is the car is fine under a healthy dose of throttle but slightly jerky under light, part throttle. Ie. when you just roll into a little at low revs. I wondered what this is. A fuel thing or an ignition thing? Too much advance?
Here's my ignition table. Thoughts?
Clonebug
Post by Clonebug » Mon Mar 19, 2018 5:46 pm
I had the same thing.
Make absolute sure you have no vacuum leaks with the intake below the throttle body. If no leaks then highlight the cruise area you are having an issue with and just bump up those bins a degree of advance at a time or lower them till it goes away. You are pretty good on advance already so if up or down 3 degrees doesn't either way doesn't cure it then you might want to also bump up the fuel bins a little at a time to see if it goes away.
I'm quite sure mine disappeared once I found my intake boots were an 1/8 inch too big and I replaced them with the correct size.
kangaboy
Post by kangaboy » Mon Mar 19, 2018 11:17 pm
...but slightly jerky under light, part throttle. Ie. when you just roll into a little at low revs. I wondered what this is. ...
I had the same dang issue. Drove like that for a bit trying to find the issue. I just gave up and tried to revert to a previous tune, which solved my problem. Still never figured out what it was, but I assume I just messed with the startup and fuel enrichment too much one way or another.
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
My Megasquirt Turbo Build
panel
Post by panel » Tue Mar 20, 2018 3:43 pm
Pete , when you're logging and you get the "slight jerk under light, part throttle. Ie. when you just roll into a little at low revs"......hit the space bar and that will throw a red line across the log right where it happened. Then show us the pic later here and we can take a look at it.
petew
Post by petew » Tue Mar 20, 2018 4:03 pm
Good thinking. But what if I'm the "slight jerk"? Oh, hang on, I'm the big jerk. :D
