type 4 motor
GARRICK.CLARK
Re: type 4 motor
Post by GARRICK.CLARK »
Hi Pile.
Well the ignition is only points and a standard coil. Plugs gapped at 28
Your probably gunna say WTF. Points and a standard coil. I went this basic to check the petronix 3 wasn't causing me big back fire issues. Well it was the module at fault. The points have been in there ever since. It works good really , Its just I cant carry on tuning more boost into it to get more power. It just starts doing this SOFT miss thing Like as if the spark gets weak and gives up at 1 bar/ high revs.
I'm not up on the distributor less ignition systems yet.
Clonebug
Re: type 4 motor
Post by Clonebug »
Try gapping at .024
GARRICK.CLARK
Re: type 4 motor
I'll try this over the week end.
Regards G.C
GARRICK.CLARK
Re: type 4 motor
So I tried my old plugs ,BP8ES gapped at 24. Motor seems ok at moment.
GARRICK.CLARK1
Re: type 4 motor
Post by GARRICK.CLARK1 »
Chaps.
Just a quick question.
Were are you getting the signal from for the dump valve.
I have mine plumbed into the manifold below the butterfly.
andy198712
Re: type 4 motor
Post by andy198712 »
GARRICK.CLARK1
Re: type 4 motor
Ok cool.
BOV/BOOST GAUGE ,below the carb plates.
Fuel pressure reg , off the turbo.
Udo Airbus
Re: type 4 motor
Post by Udo Airbus »
Correct.
Is it allowed to use the same vacuum port for the BOV/gauge/Brakebooster?
Fuelpress and wastegate from turbo..
Any pics of your engine?
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, 1915cc
GARRICK.CLARK1
Re: type 4 motor
HI Udo.
I'm using Just the Bov and gauge off a 3mm barbed fitting that's threaded into number 4 manifold. I don't have power brakes, just 4 wheel disc.
There is a pic on here somewhere.
look on late bay site, VW services section ,title is Bamber Bridge Beetles.
SU carb replaced with Dual Dells. Reason being Blow through dells are a challenge I want to conquer
Is yours on the road yet.
GARRICK.CLARK1
Re: type 4 motor
Here's a thought. Last time I had the dells working in blow through mode I was increasing the boost for more power, last high boost drive flooded the left carb badly making me think id damaged it. My fuel pressure increases with increased boost pressure. I think the extra fuel pressure due to me increasing the boost from the turbo did something to the float which flooded the engine knocking 2 cylinders out. This time I'm thinking of using a lower boost signal from the back of the turbo hat instead of direct from the turbo.
