Project CFC#1, turbo, back halfed and light (new name, new car page 15)
Kalle
Re: Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Post by Kalle »
bug66 wrote: Wed Aug 22, 2018 3:13 am Kind of slippery from time to time.. :D
Just a little :) A perfect example of what can happen when you shift gear and un-load the rear suspension in combination with a lot of power. Good save and great fun to watch from the starting line.
-K-
bug66
Post by bug66 »
Kalle wrote: Wed Aug 22, 2018 3:44 am
-K-
I see that it's a good thing to upgrade to a double adjustable damper at the back. And maybe get rid of the stance. Even though it looks cooler.. :mrgreen:
2165cc on a Borg Warner S257 SXE, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
Kalle
Post by Kalle »
A good start would be some limiter straps that does not allow a lot of camber change....just saying.
Wally
Post by Wally »
-K-
I had one of those moments at Santa Pod as well and exactly due to what Kalle describes... It got so far as that I got a little more carefull re-applying power. That behaviour didn't help ET's though!
I noticed your 10.2 was a 216 km/h end-speed. Your first runs in 2016 with 10.6 were 213 km/h though...
Any ideas as to why end-speed seems low-ish wrt your ET? Out of gear?
www.apfelbeck.nl
bug66
Post by bug66 »
Not out of gear. I had a 1.04 4th, now it’s a 1.00.
Problem is to handle all the power I dynoed with the tires. I had to go down a bit on power, even on the 10.2 run, to not smoke the tires in 1st and 2nd.
Need to manage power through the run. And a better burnout. My front runners didn’t help as much as before..
Should have had a way of having a burnout setting and a launch setting. Now I do the burnout and launch on the same setting. I could need some more punch in the burnout. But not the launch.
I still have 300 rpm to 7000 over the line.
bug66
Post by bug66 »
Kalle wrote: Wed Aug 22, 2018 10:06 am A good start would be some limiter straps that does not allow a lot of camber change....just saying.
I agree.
I managed the 1.404 60-foot with the dampers on the loosest setting.
But I wish I could have a stiffer rebound so the car would squat a bit longer..
Kalle
Post by Kalle »
You are balancing on a very fine line with those "skinny" 215/65 MH Dot tires when you reach your power level. Better go up in size (and grip) on the new car. Better safe than sorry! That said, those MH have REALLY impressed me!
-K-
bug66
Post by bug66 »
New car will have more tire..
9.5 or 10.5 DOTs.
bug66
Post by bug66 »
I tried to use the in-text picture-url thingy to show you guys some pictures of the new car. But even if the pictures is hosted somewhere else, I'm not allowed to show them here because of size :(
I'm not that keen to do all the work again, anyone know of a quick fix?
rubenski
Post by rubenski »
Get tapatalk for smartphones. Nothing to resize!
Verstuurd vanaf mijn SM-A750FN met Tapatalk
bug66
Post by bug66 »
rubenski wrote: Thu Dec 06, 2018 1:39 am Get tapatalk for smartphones. Nothing to resize!
I've tried the app before, and for me it's the most confusing app I've ever tested..
I understand that this forum wants to limit hosted photos, but URLing them from another site, and demanding a resize is weird.
rubenski
Post by rubenski »
It takes some gettin used to but for forums i dont use anything else.
bug66
Post by bug66 »
bug66
Post by bug66 »
Small update on the new car / cage / backhalfing.
3" up and 3" in.
Post by Chip Birks »
bug66 wrote: Mon Dec 17, 2018 8:23 am Small update on the new car / cage / backhalfing.
3" up and 3" in.
Looks great! I'm still trying to figure out how to pull off a raise narrow like that and retain my back seat and rear sheet metal.
