Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Moderator: seabeebuggy
bug66
Re: Yes, I'm building..., **EDIT** Bought a 2165cc :) Official 10sec car!! Now project 9sec...
Post by bug66 » Fri Jan 19, 2018 6:22 am
madmike wrote:
Fri Jan 19, 2018 6:14 am
That's a nice clean break for sure :shock: I've seen them crack but not completely off :shock: damn :lol:
Gusset's look like they will do the job :wink:
Even with clutch management it just couldn’t hold the pinion in the case. 8)
New box will be as stout as a T1 box can be :twisted:
2165cc T3/T4 turbo, DTA S60 on E85.
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
petew
Post by petew » Fri Jan 19, 2018 6:23 am
Paul Guard... drool... Does it still work?
madmike
Post by madmike » Fri Jan 19, 2018 6:34 am
I tend to like type 1 boxes, way lighter then type 2 ,,, but your knockin on that Door :lol:
bug66
Post by bug66 » Fri Jan 19, 2018 6:58 am
I think it’s a bit scuffed inside. Need to take it apart and grind/buff the housing. Or have PG rebuild it.
bug66
Post by bug66 » Fri Jan 19, 2018 6:59 am
Yeah. Bus box or mendeola would be a better choice. But want to stay swingaxle, and have the engine at the same place
Post by Chip Birks » Fri Jan 19, 2018 11:33 am
Glad to see you updating this thread with the new info. Still gonna run a decklid, or has that been given up on in effort to get that 9 sec slip?
bug66
Post by bug66 » Fri Jan 19, 2018 6:25 pm
A deck lid will fit, but will probably run without as always. Did the first plenum with trumpets inside today
petew
Post by petew » Fri Jan 19, 2018 6:47 pm
Does a decklid make a big difference at that speed?
bug66
Post by bug66 » Fri Jan 19, 2018 7:47 pm
Due to weight or aerodynamically?
My guess is that neither plays a big difference..
bug66
Post by bug66 » Fri Jan 19, 2018 7:49 pm
First plenum welded. Need to fill more argon and glue the rest together 8)
buguy
Post by buguy » Fri Jan 19, 2018 7:58 pm
Are those going to have the roundy ends on it?
bug66
Post by bug66 » Fri Jan 19, 2018 8:11 pm
Inside the plenum? Yes, the trumpets help with airflow
buguy
Post by buguy » Fri Jan 19, 2018 8:42 pm
Well I meant the roundy end caps. Or will they just be flat caps?
bug66
Post by bug66 » Fri Jan 19, 2018 8:48 pm
Ah, on the back (towards the front of the car, it will be flats, and the fronts will be trimmed for airflow and engine lid closing
bug66
Post by bug66 » Tue Jan 23, 2018 4:18 am
As you can see in the photo, the pipe going in to the plenums are not centered...
Next time I will weld the 90 degree onto the plenum and the 3/4 side is almost done. the last stage will be to close the plenums, and will do both sides at the same time.
