MadMike's 'Casper' 76 bug
- Chip Birks
Re: My latest ride
Like I said, i only have a light. Its just a bit smarter than my stock one. Not big on gauges either.
Re: My latest ride
well it was the autometer gauge ,, picked up a cheap Bosch,,,,,so it was NOT an oil pressure issue
Re: My latest ride
I was still having an oil leak issue with this sand seal pulley coller & seal well I have the collar gorilla glued in which is fine now the skinnyass seal blew out ,,, JB welded it 24 hours ago ,,, now for some testing I have a race coming up on Labor Day Sunday
Re: My latest ride
Might pay to check your breather set up if you are getting enough pressure to push the seal out, may be time to throw a leak down test on it too....
Re: My latest ride
Breather system is good , I think it was just a loose fit on the seal ,then it spun ,,so looser yet,,,JB'd it now it's good no leaks so far,,
Re: My latest ride
and everyone love's pic's
- petew
Re: My latest ride
Bahaha
You're such a craftsman.
Re: My latest ride
Very funny I should of used the newer clear stuff instead of the Original "Gorilla snot'
Re: My latest ride
I've been doing some carb swapping ,I have the 680 Quick fuel on now and it seem to be working ok , just a slight hesitation when I stomp the loud pedal
Re: My latest ride
It's so 'Humid' up here I found this in my garage
Re: My latest ride
went 'racin' won some lost some Great day only trew two or three belts ,, removed one shim then it stayed on cheapass old Flea-bay turbo is still going but only 15lbs. is all she'd do time to start saving for a good one my Son took pic's I'll see if I can get them off his phone
Re: My latest ride
no the slick's worked great 8.2 was my best pass 1/8th mile ,
Re: My latest ride
Hi Mike, I've had to do a few of those sand seal pullies lately ,I used some green lock and seal to glue it in. When they leak there's oil everywhere . The Empi sand seal pulley kit is better than the Scat one, the flange/seal is of a bigger outer diameter thus a tighter fit in the case.
