T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
petew
Re: T4 1971cc Megasquirt turbo - Budget with a lot of torque
Post by petew » Tue Jun 27, 2017 11:45 pm
sideshow wrote:
Tue Jun 27, 2017 7:48 pm
It almost seems a step backwards to increase leg pressure with a tiny disk.
200mm is good enough for formula 1. ;)
andy198712
Post by andy198712 » Wed Jun 28, 2017 4:03 am
There is just so many more disks easily available at 200mm though is the plus
sideshow
Post by sideshow » Wed Jun 28, 2017 7:11 am
200mm discs fit all the later covers and flywheels.
Post by Piledriver » Wed Jun 28, 2017 12:46 pm
To reinforce and clarify---
A hipo 200mm disk fits/works in a 210/215mm flywheel/PP combo just fine, and the 210 PP still provides more clamping force than many 200mm plates...
Kennedy can also "rebuild" a 210 PP to whatever specs you like, cheaper than a new one.
Its unfortunate they don't make low profile hipo 228mm pressure plates, the flywheel fits fine.
Udo Airbus
Post by Udo Airbus » Thu Jun 29, 2017 1:28 am
kangaboy wrote:
Tue Jun 27, 2017 7:45 am
Udo Airbus wrote:
Tue Jun 27, 2017 1:58 am
...bought a porsche...
please...do tell
Ha yes, just a very nice original Boxter 986 . Early model.. the one I loved as young guy.. It's my dailiy driver now since my wife has the familly car 8) (sorry not a 911 :lol: ) But still it drives so great... and I love to drive with the roof open (cabrio guy)
And "no" a Porsche is cheaper then Kids.. :mrgreen:
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
GARRICK.CLARK
Post by GARRICK.CLARK » Fri Jun 30, 2017 10:36 am
Pile.
The 200mm fly I bought was an AA one. Very good quality.
Udo Airbus
Post by Udo Airbus » Fri Jul 07, 2017 8:43 am
Got my VW 411 type 4 200MM flywheel yesterday! :mrgreen: +/- 7 KG! Thinking not to change it since its in a BUS (with load) (or make it 5.5KG ?)
Did some work yesterday evening:
Mounted:
- Cooling house
- 911 fanshroud
- intake system.
Still need to buy:
- oil
- turbo pressue gauge
- fanbelt
- fuelpump
- some small stuff
rubenski
Post by rubenski » Sat Jul 08, 2017 2:05 am
Pictures or it didnt happen
Udo Airbus
Post by Udo Airbus » Tue Jul 11, 2017 7:52 am
Thanks, see attachment 8)
Udo Airbus
Post by Udo Airbus » Wed Jul 12, 2017 2:39 am
Did some small things yesterday night..
Adjusted the rockers (double check)
Put oil in the engine (thanks for my brother in law to bring some)
Finalised the intake from the turbo to the heads.
Fixed the wastegate.. it was stucked due to being abused on a 2.4 (with launch control)..and not used for 3 years now :shock:
It opened at 1.7 Bar :shock: and now at 0.4 bar 8)
Next adjust the flywheel.. move the bearing from the crankshaft to the flywheel.. make oilcatch , finish the carb intake.. find a correct V belt.. and some toher small stuff :mrgreen:
rubenski
Post by rubenski » Wed Jul 12, 2017 3:52 am
Getting close!
Udo Airbus
Post by Udo Airbus » Mon Jul 17, 2017 1:31 am
Well I tried to start the engine, but no succes.
Biggest problem is the starter.. it does not turn the engine fast enough.
I tried two and a very strong Battery, but no luck.
Anybody an Idea what starter I can use? (yes I can buy a strong on that fits)
Maybe from a different car?
Thanks.
ps with no sparkplugs all ok, oil pressure is ok.
petew
Post by petew » Mon Jul 17, 2017 1:43 am
The good oil pressure is a great start. Well done.
Post by Piledriver » Mon Jul 17, 2017 2:14 am
The aftermarket geared starters seem to have issues, but every VW made in the last ~20 years has a high powered gear reduction starter, you can even get them for T1 from Bosch, new.
Notice how the motor isn't much bigger than the solenoid?
Its a permanent magnet motor, the gear reduction is a ~1/2" thick planetary set sandwiched in between the motor in the aluminum bit.
http://www.ebay.com/itm/VW-Beetle-Fastb ... wb&vxp=mtr
There is also the possibility of using a MK3/4 TDI or VR6 (both automatic) starter, one model has the required 9 tooth gear.
It needs some work with a file to bolt on, it is a 2KW unit rather than .7 KW.
Some of them seem to "kick on" before fully engaged, this will eat the ring gear, this can be fixed with some effort but the SR15N (new) is a sure bet.
There is also a PM/GR version of the VW T3 auto self supporting starter out there, 1.25KW, cant find the part# for sure.
Udo Airbus
Post by Udo Airbus » Mon Jul 17, 2017 2:45 am
Wauw thanks for the Quick reponse!
@ PeteW yes thats the first step
@ Piledriver, thanks! I was searching and I can order one in Netherlands for 143 euro. (164 dollar)
It the magnet version with 1.4 KW ..bolt on..
First I will ask my watercooled brother in law if he have some vr6 or Tdi starters.. otherwise I will buy the strong version if I get approval from my wife :D
