T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
Udo Airbus
Re: T4 1971cc Megasquirt turbo - Needs advice on turbo intak
Post by Udo Airbus » Wed Feb 10, 2016 7:16 am
Ok some last pic's with the engine in....
Now cleaning the engine bay, and put back the 1600cc for this season.. (I sold my house, and a new kid is coming.. so I have very limited time for the T4T..)
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
rubenski
Re: T4 1971cc Megasquirt turbo - Budget with a lot of torque
Post by rubenski » Fri Feb 12, 2016 4:44 pm
Engine bay looks clean! So the turbo is on hold? Doesnt seem that far from finished?
Udo Airbus
Post by Udo Airbus » Tue Feb 16, 2016 10:51 am
rubenski wrote:Engine bay looks clean! So the turbo is on hold? Doesnt seem that far from finished?
Thanks!
It is actually.. need to buy all sensors//fuel stuff.. megasquirt system.. injectors.. upgrade gearbox....etc..
Udo Airbus
Post by Udo Airbus » Fri Jul 01, 2016 9:25 am
Yes I'm back! My Daughter has been born, and we got a new house now.. i'm rebuilding the Garage and bought myself a engine mount.. it's very easy now..
Then in a couple of months I can continue to work on the T4T
ps too bad all the pictures are los from older posts.. :roll:
petew
Post by petew » Fri Jul 01, 2016 6:48 pm
Congrats! Sounds like life is busy for you all. :)
Whenever you're ready for some new pics is fine.
Udo Airbus
Post by Udo Airbus » Mon Jul 04, 2016 7:16 am
Thanks PeteW!
Some old/new pics..
When i bought it 6 years ago..
Last week picking up some carpet..
(Big image here: http://images.thesamba.com/vw/gallery/pix/1525824.jpg)
Fitting the T4T last winter...
petew
Post by petew » Mon Jul 04, 2016 8:54 am
Make it run! :)
Udo Airbus
Post by Udo Airbus » Thu Sep 29, 2016 7:12 am
Finally a small update.
Got my 36-1 wheel installed. (sensor almost)
Fuel rails are in progress.
Tonight I'm going to place the MAP sensor in the intake..
Udo Airbus
Post by Udo Airbus » Thu Sep 29, 2016 8:08 am
Difficult, maybe you can advice me;
I got EV14 long nozzle injectors, and I am Looking for a 550-650 cc injector.
Yes prosche GT3 uses 630cc injectors that will fit,, but that price! pff
Anybody that can advice me from what car I can use them..?
Currently I got the BMW k1300RS injectors
part no: 0280158037 - 7677017 (K40) they are 246CC
Thanks for the help/advice
Udo Airbus
Post by Udo Airbus » Tue Oct 11, 2016 4:53 am
did some small updates..
Added:
- thriggerweel + sensor..
- Map sensor
- idle valve + connectors to intake..
- bracket for coilpack..
To do;
- boost controller
- new coil cables..
- turbo oil feed + return
- fuel rails
- 200mm flywheel
- injectors
- air intake
- correct v- belt
- complete ECU system..
- seals for the cooling system
- make a bracket for throttle connection
- finish all welds, and get everything painted
Post by Piledriver » Wed Oct 12, 2016 2:10 am
Nice setup, plenty of room to add an intercooler.
Udo Airbus
Post by Udo Airbus » Wed Oct 12, 2016 9:30 am
Thanks, yes will add that later.. first try to start the engine,,
Udo Airbus
Post by Udo Airbus » Tue Feb 28, 2017 10:49 am
Oke i'm back..
Since my EFI budget is $ 000,- at the moment, I'm changing plans.
I will use a weber 44 idf and make it as central carb, then i can start the engine for the first time. (with the 228 flywheel)
After that I will config it as a blow trough setup.
One small problem; I will use a normal 009 distrubutor, and then I need to drill a new connector for the engine case breather.. So I need to split the engine again...
I hope to start the engine in 2 months :mrgreen:
Wally
Post by Wally » Tue Feb 28, 2017 3:21 pm
I would then rather wait a while over using a carb and 009 as you are so far already towards completing your EFI set-up!
Udo Airbus
Post by Udo Airbus » Wed Mar 01, 2017 9:57 am
Yes Wally! But since you (and my Brother in law with a 2.4) motivated me to make the engine running (without turbo) I need to make some decisions...
8)
