T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
petew
Re: T4 1971cc Megasquirt turbo - Budget with a lot of torque
Post by petew » Wed Mar 01, 2017 3:48 pm
Yeah, get it running. Turbo later. A running car is worth more than a dream setup. :)
Udo Airbus
Post by Udo Airbus » Fri Mar 03, 2017 6:36 am
Thanks Petew! Yes you are right!
Its my spare engine, but after 2 year I want to see it run!
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
sideshow
Post by sideshow » Fri Mar 03, 2017 9:05 am
I also agree that carburetors and points do far less damage than jack stands and age.
Udo Airbus
Post by Udo Airbus » Fri Mar 03, 2017 9:22 am
:lol: :lol: :lol:
Post by Piledriver » Fri Mar 03, 2017 12:46 pm
Agreed.
Udo Airbus
Post by Udo Airbus » Tue Jun 06, 2017 4:58 am
Made single weber setup (2x44mm)
Need to finish welding and paint..
We will see ..
bigger image: https://www.thesamba.com/vw/gallery/pix/1651661.jpg
petew
Post by petew » Tue Jun 06, 2017 7:04 am
Great stuff, but you really want that T manifold with the turbo feed going right into the middle at right angles to the pipe. Otherwise you end up running one bank leaner than the other. All the old turbocharger books warn about it.
Udo Airbus
Post by Udo Airbus » Tue Jun 06, 2017 7:15 am
Thanks Pete..
I was already afraid of this.. with a injection engine its not an issue.. with carb different.
What would be the best? 2 x 90 bents? or should it be exactly at the middle?
GARRICK.CLARK
Post by GARRICK.CLARK » Tue Jun 06, 2017 2:50 pm
It looks cool , I had mine similar to that and it was a bitch to get started what with the manifolds being long and the engine having to draw fuel up hill like that. I had to spray easy start into it .
petew
Post by petew » Tue Jun 06, 2017 7:15 pm
Thanks Pete..
This is the page from the Hugh McInnes book, "Turbochargers".
He's specifically talking about flat motors. I don't think it matters a lot what's in between the turbo and the cross manifold as long as you can keep it as short and direct as possible.
panel
Post by panel » Tue Jun 06, 2017 9:05 pm
Udo Airbus.....have a look at this vid.......
https://www.youtube.com/watch?v=xFB_xg1gKnI
Subaru JDM EJ20 Turbo bus
Udo Airbus
Post by Udo Airbus » Wed Jun 07, 2017 1:38 am
@ Pete, Ah very cool! thanks for the reply.. it will be very difficult with the porsche fanshroud.. and the normal ignition..
@ Panel, yes I saw this last week, very cool thanks :)
Udo Airbus
Post by Udo Airbus » Fri Jun 09, 2017 2:06 am
ok made a other intake...
The T Mainfold in exactly in the center now , including the lenght icm the bents.. The inside is very smooth.. need to grid the other welding.. (is only outside) Also the intake is about 20 cm shorter..
Hope this will work..
Wat jet's can you advice for my IDF44? I got a stock 1971cc with a webcam #119 and T1 lifters with TD04-13T turbo, thanks!
Large image: https://www.thesamba.com/vw/gallery/pix/1652989.jpg
petew
Post by petew » Fri Jun 09, 2017 6:10 pm
That's a lot better. What are you doing for ignition?
Udo Airbus
Post by Udo Airbus » Mon Jun 12, 2017 9:16 am
Thanks Petew ! For now I use a 009 and will lock it around 24..
Just temp till I got all my EFI stuff complete..
