T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
blue thunder
Re: T4 1971cc Megasquirt turbo - Budget with a lot of torque
Post by blue thunder » Tue Jun 13, 2017 12:53 am
Does your turbo have a carbon-seal? If not, you have a big chance of sucking the oil out of the cartridge which will result in alot of smoke...
Udo Airbus
Post by Udo Airbus » Tue Jun 13, 2017 1:47 am
It's a TD05 13T
Don't think so :o
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
madmike
Post by madmike » Tue Jun 13, 2017 6:15 am
I'd try it :wink:
-3 Inlet hose size and a -10 out May not even smoke ,,,, :roll: :lol:
Udo Airbus
Post by Udo Airbus » Tue Jun 13, 2017 9:07 am
We will see :D
GARRICK.CLARK
Post by GARRICK.CLARK » Sun Jun 25, 2017 4:26 am
Any updates Udo
Udo Airbus
Post by Udo Airbus » Mon Jun 26, 2017 1:50 am
Not yet :) thanks
Too busy with the garden , and making the split ready for the european bug-in!
Also waiting for a T4 200mm flywheel..
GARRICK.CLARK
Post by GARRICK.CLARK » Mon Jun 26, 2017 11:49 am
Ah ok.
I've just changed my 210mm fly for a 200mm one . I forget the make of it , very good quality, I used the same 3 end play shims too as the new flywheel didn't change the end float measurement. put a daiken disc in and a stage 2 kennedy pressure plate. The stage 2 isn't that much harder to press either.
petew
Post by petew » Mon Jun 26, 2017 4:59 pm
I've got a stage 2/daikin disc in my car. It's overkill for my setup, but probably right for a bus. As Garrick said, you get used to it. Works quite well.
Post by Chip Birks » Mon Jun 26, 2017 8:37 pm
Are you planning to launch the bus? I don't know why you'd need a stg2 in a street driven bus, you aren't making 200+ are you?
Post by Piledriver » Mon Jun 26, 2017 11:46 pm
Ah ok.
Post it or the source up if its decent , need to support suppliers of decent parts!
(and shame all those who sell garbage)
Udo Airbus
Post by Udo Airbus » Tue Jun 27, 2017 1:58 am
Thanks! I hope to get around 110 HP with this setup. and 150nm ? So we will see.. I think a stage 2 kit should be ok. I would prefer a hydralic clutch but have no space under the fueltank..
First make it run..(after 3 year) and continue in saving money for EFI.. (ah yes, moved, new garage, 2 kids, bought a porsche... etc ) :D
kangaboy
Post by kangaboy » Tue Jun 27, 2017 7:45 am
...bought a porsche...
please...do tell
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
Post by Piledriver » Tue Jun 27, 2017 6:08 pm
I bet the two kids work out cheaper than the Porsche :twisted:
petew
Post by petew » Tue Jun 27, 2017 6:55 pm
I think you might find otherwise... :roll:
sideshow
Post by sideshow » Tue Jun 27, 2017 7:48 pm
Not to micro manage the project, but the 210mm bus clutch is a great driver clutch.
It has near the clamping force of a 1700 aftermarket and the pedal feel of stock with a sprung center.
It almost seems a step backwards to increase leg pressure with a tiny disk.
