T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
buguy
Re: T4 1971cc - Draw Through Turbo - VW Splitscreen - Movie @ page 10
Post by buguy » Wed Aug 02, 2017 10:30 am
I just drilled a hole in the stop on mine and put a small allen head bolt in it so I can turn it in and out to adjust the stop.
Udo Airbus
Post by Udo Airbus » Thu Aug 03, 2017 1:09 am
Yes, I did the same yersterday evening.
After testing still problems.
If I rev the engine at around 4000rpm it pops very hard from the exhaust. maybe its running to rich? anybody some idea's?
Also the sparkplugs from cil 1, 2, 3 are bit brown.. no 4 is still clean..
Or the old cilinders have oil problems @ 1,2,3, or we have some problems with the sparkplug or cable @ no 4..
The ignition setup comes from my perfect running 1600.. still I will change out the cables..
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
Udo Airbus
Post by Udo Airbus » Thu Aug 03, 2017 3:58 am
Thansk MegaRookie for your Dutch PM! I will do the check asap :)
Compression, sparkplugs, rockers... AFR meter install + logger..
kangaboy
Post by kangaboy » Thu Aug 03, 2017 9:54 am
Mine pops when its lean, typically on decal. You could be pinging. Do you have an AFR gauge? Its pretty much a must have for running setups like this. That would tell you rather quickly what is going on, and I suggest getting one before any tuning is performed. If you are going lean up in the boost area (which it sounds like you are at ~4000rpm), you're gonna do some damage.
'74 Standard- 1776T, MS3X3
'76 Westy- Stock 2.0L L-Jet
Udo Airbus
Post by Udo Airbus » Wed Aug 09, 2017 7:06 am
I measured the CR and it was exact on all 4 cilinders: 8.3:1
Rockers are al ok.
I will order some new sparkplugs for now and yes will install my AFR gauge.
Thanks.
qaxa
Post by qaxa » Sat Sep 02, 2017 2:25 am
Any update on this? Interesting build so keen to read about latest developments wrt project.
How much boost you are running? Still on stock pistons?
Are there any 24mm pin 94mm forged pistons available? 96mm are but 94mm I haven't seen?
Post by Piledriver » Sat Sep 02, 2017 1:49 pm
JE, Wiseco or Ross will make you a forged piston any way you like.
I suggest 4032 alloy if its not a trailered track queen.
Udo Airbus
Post by Udo Airbus » Tue Sep 05, 2017 4:04 am
Thanks! not much to update.. busy with other things..
Still not running ok in high rev's, look like smaller venturi's will help.. Still thinking to convert to blow trough .. then i'm also able to run without turbo pressure.. (I think, at the moment my intake is too long..)
Yes , i'm running stock pistons..(budget build) we will see how long they will survive..
Post by Chip Birks » Tue Sep 05, 2017 12:51 pm
Have you actually installed it in the bus yet? Or are you just tuning it while free revving on your engine stand?
Udo Airbus
Post by Udo Airbus » Wed Sep 06, 2017 2:14 am
I cannot install it in the bus yet.. maybe this winter..
GARRICK.CLARK
Post by GARRICK.CLARK » Wed Sep 06, 2017 2:34 am
Udo.
I had my intake similar to yours with a long intake. I Couldn't get it to run right at all, tried everything. Took ages to start. Flat spot due to intake length , fuel puddle in bottom of turbo. Go blow through its much better. I will post a pick of mine, might give you some ideas.
Udo Airbus
Post by Udo Airbus » Wed Sep 06, 2017 3:25 am
Yes that were my Thoughts too, starting already takes ages.. yes please share some pics! Thanks!
GARRICK.CLARK
Post by GARRICK.CLARK » Wed Sep 06, 2017 5:36 am
Ok be back soon Udo.
GARRICK.CLARK
Post by GARRICK.CLARK » Sun Sep 10, 2017 7:34 am
Hi Udo.
SO I've gone from draw through SU to Blow through with the same SU carb
Udo Airbus
Post by Udo Airbus » Tue Sep 12, 2017 4:55 am
Hi Garrick, thanks but I cannot see the picture.. Some photobucket 3rd party hosting error.
SU carb? Nice whats the setup? were is the carb from?
