T4 1971cc - Blow Through Turbo - VW Splitscreen - NEW Movie @ page 13
Moderator: seabeebuggy
GARRICK.CLARK
Re: T4 1971cc - Draw Through Turbo - VW Splitscreen - Movie @ page 10
Post by GARRICK.CLARK » Tue Sep 12, 2017 1:15 pm
God no's why photo bucket do this. I've seen it before with other dubbers photos , I'll bet they want money. I see if I can fix it.
My carb is an SU HS8.
Clonebug
Post by Clonebug » Tue Sep 12, 2017 4:05 pm
Photobucket does want money but if you use Mozilla Firefox as a browser they made an add on that will allow you to see photobucket photos....
I'll find the link and post it tonight...
petew
Post by petew » Tue Sep 12, 2017 6:46 pm
GARRICK.CLARK wrote:
Sun Sep 10, 2017 7:34 am
Hi Udo.
SO I've gone from draw through SU to Blow through with the same SU carb
Interesting setup. A few questions...
1. What is the pipe coming up under the carb? A preheater?
2. How did you sort the tinware around the back of the motor? Did you just leave it open like that?
GARRICK.CLARK
Post by GARRICK.CLARK » Wed Sep 13, 2017 1:43 pm
Hey thanks Clone.
Pete, the tin ware were the front pulley isn't there, just the CSP head tins. The heater out lets on the fan shroud are cut off and plated, gotta 356 top pulley fitted. There is a good amount of air blowing through the heads. If I rev it at idle the air blown through the heads will move leaves/dust/etc from under the car(The area directly under the heads)
Do you mean the 90 degree blue pipes, If so that's from the turbo out pipe to the front of the carb.
Udo Airbus
Post by Udo Airbus » Thu Sep 14, 2017 2:04 am
Thanks CloneBug, that works :)
Cool setup Garrick, how much HP/torque do you run? I alos see plenums? No problem since air and fuel are passing them?
I'm planning to make an intake with central weber 44.
VW T1 1964 - Mouse Grey - Pearl White OG paint
Bagged, Porsche steeringrack/brakes..IRS, AMR Supercharged 1600 (sold) building a 1971cc EFI turbo/supercharged engine
GARRICK.CLARK
Post by GARRICK.CLARK » Thu Sep 14, 2017 2:27 pm
Hi Udo,
I'm unsure on Hp/Torque ,not been to a dyno yet. Its a 2"manifold to the Inlet manifolds, They are welded CSP manifolds. The turbo out pipe and hoses are 2" so is the Carb. I thought it might be too big a diameter but it seems fine. To start it I just lift the choke lever on the carb and wait for the engine to draw some fuel from the Jet. Takes about 20 seconds to catch, During this 20 seconds the oil light has then gone out as well. My draw through set up used to warm up the starter it took that long to catch.
Udo Airbus
Post by Udo Airbus » Fri Sep 22, 2017 8:45 am
Ok thanks Garrick, 20sec starting.. for me too long :)
Some updates on my engine.
- Got the flyheel modded to fit on my type 1 trans (replace needle bearing)
- ordered intake pipes/ turbo hoses to make 1 central weber carb at the back of the fan house.
Then I will test start the engine, and put it in the car .. after that I will make a exhaust muffler + connect the AFR.. and then the fun may begin..
Udo Airbus
Post by Udo Airbus » Fri Sep 29, 2017 2:51 am
Small update, intake in progress.. 8)
Wally
Post by Wally » Fri Sep 29, 2017 4:02 am
It does look kinda neat and simple, I must admit!
Udo Airbus
Post by Udo Airbus » Fri Sep 29, 2017 4:30 am
Thanks Wally, yes its just fun to make and do.. and it's even cooler if it will work..
But it will be never so professional as your engine :D
rubenski
Post by rubenski » Fri Sep 29, 2017 4:57 am
Nice!!!
petew
Post by petew » Fri Sep 29, 2017 7:17 pm
Blow through?
P.s. love those hand prints
Udo Airbus
Post by Udo Airbus » Tue Oct 03, 2017 1:43 am
Thanks, yes Blow through... (ha my son made them when he was 1.5 years old, thanks)
Yesterday started the engine with only the carb. It was running perfect, but one problem.. the blue intake hoses are squeezing.. so I need to make them from steel.. grrr
I was also forgotten that there was sitting some old fuel in the turbo.. lol (yes there was no hose connected) It felt like a shower
I'm also at a point now to make a intake plenum on top of the IDF carb, anyone idea's how to make this myself ? (I cannot weld aluminum)
Thanks.
66brm
Post by 66brm » Tue Oct 03, 2017 7:07 am
Could you use one of cbperformances carb hats? Cheaper than making one
Udo Airbus
Post by Udo Airbus » Tue Oct 03, 2017 9:00 am
Yes I would like, but cannot find them in NL at the moment
