Did you make sure all the retainers have a slight gap when around the valve???66NCVW wrote:Well I installed my HD singles today and ran into this problem. Both of these springs are for the exhaust valves on the same head. Both with a .015 shim under them. Tight coil verified to be on the bottom. Here is my problem. Notice the retainer on the right doesn't seem to come up as high on the keepers as the one on the left. It's noticeable with a ruler across them as well. Any ideas? The retainers were all level with the stockers.
Sometimes you have to sand a little off the flat sides to make sure they don't touch.
