1835 36 PICT 3 Turbo BUILD
Re: 1835 36 PICT 3 Turbo BUILD
Good to see your back at it
- rubenski
Nice topic. It was time for some new builds!
- bikesndbugs
what kind of adjustability does the blackbox have is it boost referenced timing.Coyote wrote:The ignition system :
009 distributor with Compufire module
the CB Blackbox.
The installation was very straight forward : just followed the instructions and voila !
my initial setting is 15°, light load cruising is 35° and at full boost is 22°.
This thing work perfectly from the beginning.
Travis
- rubenski
It has a internal map sensor. You can control timing with input from rpm and load / boost.
It is a nice kit. I have it too, a while back at my supercharged project and now just on my engine NA. Does a great thing on normal stock engines too.
It also has revlimiter and 2 step.
For the money not a bad product. I would advise it to anyone taking the first try at going forced induction.
Ruben
Ruben
- panel
Just what I was thinking alsorubenski wrote:Nice topic. It was time for some new builds!
- Coyote
Thank you for the kind words. It's a pleasure to be back here !madmike wrote:Good to see your back at it
2276cc daily draw though
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- Coyote
I can't say more than what Rubensky already wroterubenski wrote:It has a internal map sensor. You can control timing with input from rpm and load / boost.
Ruben
It 's very easy to install, and not complicated to tune. you already have two ignition maps (10psi and 18psi) to start with.
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- Coyote
The vaccum port under the trottle for the Blackbaox and the BOV :
And a boost box, found on ebay, for the wastegate, fuel pressure regulator, the Water Injection system :
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- Coyote
The fuel plumbing is finished. one AN6 in the Fuel pressure regulator, the return also in AN6, and one AN4 to the carb.
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- Coyote
It's time to assemble the 1835cc engine. The volume combustion chambers are 53cc, so with a DH of 1.23mm (0.048") my CR is 8.5/1
The ring gap opened up to 0.50mm. It was at 0.40mm before, and that's not enough for turbo charging
The short block is OK :
And the jugs ready to install with teflon buttons:You do not have the required permissions to view the files attached to this post.
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- rubenski
You got skillz! Seems you tackle this build the right way! Not just add a turbo on a stock engine and see what goes wrong!
Thumbs up!
Thumbs up!
- Coyote
Thank You Rubenski.rubenski wrote:You got skillz! Seems you tackle this build the right way! Not just add a turbo on a stock engine and see what goes wrong!
Thumbs up!
I usually read a lot and think long before starting anything ! .
Breaking parts is always expensive and time consuming. So the goal is learning a lot before starting anything.
Especially if you are tight (I am always) on budget like me !
I started turbocharging (draw through)in 2007 and I quickly realized that it was necessary to respect certain rules when starting in turbo. especially doing nothing without a wideband. It's just impossible. Turbo is funny ( I will never come back to NA)but things can go wrong very fast !
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- Coyote
First installation in the car. Of course, this is not the right way to install the air filter ! just for starting the engine.
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- Coyote
Here's a close up. you can see the crank evac system. Only one hose that go from the CB breather box to the exhaust. That's enough for me. no valve covers venting.
ET: 11.67
MPH: 119.64
ET: 11.67
MPH: 119.64
- rubenski
