2109cc turbo build...
Moderator: seabeebuggy
rubenski
Re: 2109cc turbo build...
Post by rubenski » Mon Jul 23, 2018 9:40 pm
I say verry clean!!!
petew
Post by petew » Thu Jul 26, 2018 12:32 am
Have you got decklid stand offs? That would scoop cool air into the engine bay and help bring the temperature down.
btw, looks like a great little car. ☺
Volky
Post by Volky » Mon Sep 03, 2018 9:02 pm
Hi,
When I turn on the car in the morning it barely idles when cold. I then touched the #1 exhaust pipe and it is warm to the touch. You can even grab it. Not the others, those will burn your hand. I thought it was the spark plug, changed it and still the same.
Any thoughts?
1970 VW Beetle with 2109cc turbo with MS-II v3.0, wasted spark, electronic boost controller, dual table, launch control and 3.88 tranny. All done by me...:) t03 running 48lb. Injectors, Intercooler, Water/Meth injection at 15psi.
petew
Post by petew » Mon Sep 03, 2018 9:14 pm
Have you tried pulling off the plug wire when it's running and seeing if there's any change?
66brm
Post by 66brm » Tue Sep 04, 2018 12:12 am
Also you could move that injector to see if it follows otherwise it could be wiring to the injector
Post by Piledriver » Thu Sep 06, 2018 6:18 pm
...could be a tight valve...
