Going back in
madmike
Re: Going back in
Post by madmike »
Play with the E-tube's :wink:
Re: Going back in
I will do that, found this info so far. I did change them to the T tube when I put the Turbo back on. Thanks for the direction.
Re: Going back in
I removed the T e tube and installed a -1, I also went to a 1.73 main, so I have a 200 air, -1 e tube and a 1.73 main. AFR at 5 lbs boost was 11 afr, going to go to a 1.70 main and see what AFR's are then.
How close to 14.7 do I want to be on idles and at boost. I am happy with the 5-7 lb boost, I have gotten carried away before though fun it was expensive. Thank you for the help guys!
Clonebug
Re: Going back in
Post by Clonebug »
You just want to do the usual "best lean idle" which for my engine always seemed to be about 12.8:1 AFR.
As far as AFR on boost it could be anywhere from 11.0:1 and maybe richer but shooting for 12-12.5:1....
It still depends on what your engine wants and if you are fighting detonation or not.
Re: Going back in
Clonebug wrote: Sun Feb 26, 2017 9:07 pm You just want to do the usual "best lean idle" which for my engine always seemed to be about 12.8:1 AFR.
I am getting close, thank you for the info.
GARRICK.CLARK
Re: Going back in
Post by GARRICK.CLARK »
Have a look at this site. Performance oriented..... a passionate pursuit.
