1600 turbo build thread
- Chip Birks
Re: 1600 turbo build thread
Cb are nice. Scat too. Just be prepared for more than the 1.4 advertised ratio. My CBs were around 1.5:1.
- buguy
If I end up going with the Web 86A that should be no problem. I can't imagine a little more lift being a bad thing. It has a .502 lift with a 1.5 ratio.
- V8Nate
My CB 1.4s with the 86a cam measured out at an exact 1.4
- buguy
What's the rest of your setup?
- V8Nate
AA 80mm crank, AA 5.4 h beam rods, AA 90.5 b pistons, AA 500 40x35.5 heads, web 86a cam, cb 1.4s, cb HD aluminum p/r's, 26mm cb oil pump, silverline main and rod bearings, mahle double thrust cam bearings, helical cut cam gears, AA 1.5 sidewinder style exhaust. Serpentine pulley cut for hidden crank trigger by Mario at the dub shop. I plan on throwing some boost at it so went with 8.45-1 comp. Ratio slightly less than web calls for and that's with a .042 deck
- buguy
Sounds pretty close to what I'm doing. I will have a bit less compression (7.5-8:1) and I'm using chromoly pushrods. I will probably have a bit more deck too depending on how it all comes out.
- V8Nate
Luckily for me I had +.007 deck with no shims so I just needed the correct amount of shims to get my deck correct. I believe I have 62cc combustion chambers in my aa heads but its always wise to measure everything no matter what is advertised.
- buguy
Yeah I'm planning to get my Panchitos with 68cc chambers so I don't have to go too crazy with the deck to get my compression where I want it.
- V8Nate
Excellent, I think the next pair of heads I get will be some panchitos I checked a pair out when I was at Mario's and you definitely get what you pay for. I would be miles ahead if I would have spent the money beforehand, but for the money I still dig em.
- buguy
Yeah boost seems to be a good equalizer.
- buguy
Ok since I'm getting a bunch of stuff from CB do I want one of those Maxi oil pumps with the in/out on it , or should I just get a regular one? Probably sticking with 26mm.
- V8Nate
26mm for sure, single outlet, full flow case tried and true!
- Chip Birks
You gonna feed a turbo and external oil cooler? I've never used the in/out type, I always just full flow my cases. I run 30mm pumps, but also have lots of oil line, a big cooler and thermostat and filter in my system.
- buguy
I don't have an oil cooler at the moment. But I did tap the case for full flow. Didn't know if that Maxi would be simpler?
I plugged your numbers into the engine calculator and I come up with 9.0:1 compression if you use the CNC 61cc panchitos with a 82X94 and .050 deck.
Why would you want to have to hog out the chambers to 68cc's??
If you use a Webcam 86B or similar with a little duration you will be just about perfect.
Don't make your engine a dog off boost with 7.5:1 compression.
