1600 turbo build thread
Moderator: seabeebuggy
Clonebug
Re: 1600 turbo build thread
Post by Clonebug » Fri Apr 27, 2018 4:46 pm
Chip Birks wrote:
Fri Apr 27, 2018 12:24 pm
Pretty sure its just a modified one. I'll ask him...
Who's Bug is that???
Engine?
Turbo?
Details???
:shock: :wink: :lol:
Post by Chip Birks » Fri Apr 27, 2018 5:08 pm
His name is Chrys Espejo, he's on facebook. He races Unlimited Street, is from California, runs e85 most of the time, if not exclusively. Air to water intercooler. I think its gone 10s. Nice guy. Cool car.
buguy
Post by buguy » Fri Apr 27, 2018 7:54 pm
Yeah it looks like pretty big pipe!
theKbStockpiler
Post by theKbStockpiler » Fri Apr 27, 2018 8:33 pm
Here's a link that brings up a lot of turbo bug builds. https://www.youtube.com/watch?v=AntlkT6ybVo
The only header I have seen that keeps the turbo out of the engine bay is the CB. If having the turbo/exhaust in the engine bay is not a problem or having unequal length primaries , the fabrication gets easier.
Super beetle with attitude
Post by Chip Birks » Fri Apr 27, 2018 8:36 pm
My a1 puts the turbo in the same spot, but no pipe in the back of the engine. The primaries all run forward and the wrap around to the 3/4 side.
buguy
Post by buguy » Fri Apr 27, 2018 8:42 pm
That's kind of how I was thinking to do it. Run the 1/2 side around the forward part of the engine and end up back around by number 4. Or maybe keeping it kind of like it is now but running a little bit lower in the back so things don't have to be so tight running back up.
theKbStockpiler
Post by theKbStockpiler » Fri Apr 27, 2018 9:02 pm
I just came across the DRD header.
Post by Chip Birks » Fri Apr 27, 2018 9:10 pm
DRD used to sell the A1 header, thats the one I have. Pretty sure DRD has closed its doors.
theKbStockpiler
Post by theKbStockpiler » Fri Apr 27, 2018 9:16 pm
It just occurred to me the if the primaries are not equal length, they are not technically a header and are a 'tubular exhaust'.
buguy
Post by buguy » Fri Apr 27, 2018 9:40 pm
That's pretty much the vision I had for it. But I would think the turbo would need to be a bit higher for drainage? Do you have to run a scavenge pump Chip?
Post by Chip Birks » Fri Apr 27, 2018 9:52 pm
I've never had a problem.
theKbStockpiler
Post by theKbStockpiler » Fri Apr 27, 2018 10:20 pm
Chip, do you find that SS stays that much cooler and really does not need to be insulated?
Post by Chip Birks » Fri Apr 27, 2018 11:26 pm
My header is MS. I'm gathering a whole bunch of stainless bits to do a new header, but not ready to do it yet. My steel one has definitely done some corroding. Its still sound, for now. I mainly want the stainless for its durability.
buguy
Post by buguy » Sun May 06, 2018 8:07 pm
I'm ordering up my bends tomorrow. Its a bummer because the place with the cheap bends has nice flanges for sale too but no cheap collector. The next more expensive place with bends has a cheap collector but don't have thick flanges. So I have to order from 2 different places.
I'm really tempted to try blowing through one of these carbs but it sure seems like the throttle shafts would be a huge leak. I would also probably have to put an electric fuel pump on... Maybe. I don't really know what pressure the stock mechanical pump puts out. I believe a Holley is good to 7 pounds of pressure before overcoming the needle and seat. So if I have to bump the fuel pressure up as boost rises I could need as much as 17 pounds (assuming I run 10 psi of boost).I can't imagine I can get that from a stock pump.
Clonebug
Post by Clonebug » Sun May 06, 2018 10:36 pm
You might want to check this out before placing your order.
They even have a cheap collector and you can get it in 1 3/8ths if you want.
http://www.greatplainsas.com/scexhaustparts.html
